Spark plug question...
Old Mar 13, 2006
gh0st's Avatar
TAQUITOS!!!!
So I've been trying to read up on which ones are best, but while searching, I'm coming up with spark plugs for those with turbo's or other mods.
My car is stock so I'm pretty much looking for a replacement to stock spark plugs. Would it be in my best interest to use the OEM spark plugs or pick up a different brand?
Also, what kind of socket should I get for the plugs? I'm seeing a bunch of different sizes. I only have a torque wrench for 1/2" drive.
Thanks for looking.
Old Mar 13, 2006
DDragon7's Avatar
I know that NGK and Denso are pretty good, there has been debates of what types that would be good on our cars, copper, platinum or iridium. I believe stock plugs are platinum. Yesterday I was looking at some NGK iridium spark plugs pretty expensive, but I think I will still go with it and try it out.
Old Mar 13, 2006
Jrfish007's Avatar
Here is what I do... first of all the idea that you plugs can go 110k miles is BS. I go with an old school train of thought that I would rather change them more often with cheaper plugs than less often for plugs that cost 4-5 times more. So I go about 25-30k on cheap platinum. Yes there are cheap and expensive platinum, and the difference is the core. In the cheap ones you have a copper core where as the expensive ones you have a platinum core, you are looking around $2-3 versus $15-20 respectively. You will not get any better performance or anything like that out of them, the only reason for having a platinum core is to make the plug last longer, but not 5 times longer.
As for the turbo ones and all that, don't worry about that stuff. The only reason for that is because if you have some super powerful engine it may need more power to cause a proper spark, in which case you also need a strong ignition coil(s). You may also want to change the heat rating of the plug to prevent pre-ignition, but since you don't fall into this category, don't worry about it.
Stock plugs a platinum tip and core... quite costly as you mentioned.
Old Mar 13, 2006
CuRiOuSfIsH's Avatar
Back From The Banned!
I would just go with OE
Old Mar 13, 2006
platinum runs too hot which is bad for turbo. For a regular civic, ngk v-power copper plugs will do just fine. $8 for 4 of em and they work just as good as iridium.
Old Mar 13, 2006
goodtimes's Avatar
when you get your spark plugs make shoure you gap them to 0.04
Old Mar 13, 2006
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
how do you gap them? i've change spark plugs on my family van and my brother car, and my own honda prelude...i just tighten dem just enough usin the extention by hand, den turn it a half turn more with the umm...dunno wut its called...haha
o the socket wrench..
Old Mar 13, 2006
gap is actually checking the space between ground electrode and center electrode. they sell gap tools like a disc that you slip inbetween and read how much gap there is. they are supposed to come pregapped but you never know. then when installing, yes you need to torque them to spec. that means tightening 13ft/lbs with a torque wrench.
Old Mar 14, 2006
Jrfish007's Avatar
You aren't suppose to gap platinum plugs. The little tiny wire the is the electrode may get damaged in the gaping process.
Old Mar 19, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
socket you get is a 5/8 spark plug socket. harbor freight (store only apparently as I can't find it online) has a 5/8 spark plug socket (with wobble joint) on what I think is like a 8-10 inch socket extension. or jsut go to autozone or something and ask for the basic 3/8 socket kit. it has a driver and a spark plug socket, with a rubber insert to hold onto the spark plug.
something tells me you've already found this info out, as I'm trying to respond to a 5 day old post.....
Old Mar 23, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
85,000 miles on the oem denso plugs. ill be replacing them with the same, they have done their job well thusfar, no reason for me to change. and you should gap them .044
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
