Lighter Fuse
Old Mar 2, 2006
Toaster's Avatar
Toaster is on a distinguished road
Lighter Fuse
Wifes 2004 VP keeps blowing the fuse when using cell charger. Tried plugging everything in with car off, tried leaving just the cord plugged in (both to eliminate possible short inside outlet), tried plugging it in after starting (seems the worst). Was going to pull console and check wires and possibly hard wire it in. Any one else have this problem? Also can I just cut the cell charger and directly wire it or is there something in the end that limits the voltage?
Old Mar 2, 2006
MegaHurtz's Avatar
What size fuses are you blowing? Do they blow instantly?
Old Mar 2, 2006
Toaster's Avatar
Replaced the stock 15 with 15 numerous times. Seems almost instantly today blew 2 before we left the drive way.
Old Mar 2, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
maybe its just the charger ...maybe?
Old Mar 2, 2006
Toaster's Avatar
That was my other thought. Any easy way to check it without buying a new one? Could probably borrow one from a friend. Also does not seems to blow the fuse in my 2003 EX.
Old Mar 2, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
do you have anything else tapped off your lighter circuit that might be close to 15 amp, then when you connect the charger, it brings it over 15 amp, which blowes the fuse? cause a phone charger does not draw close to 15 amp. it might be your charger, if you have a dmm, you could test it on your battery, with the dmm inline (make sure to connect right terminals to right in circuit). dmm negative to negative on battery, dmm positve to charger sides, charger tip to battery positive, set your dmm to mesure amps, and it will tell you how much power it draws.
Old Mar 2, 2006
05reverb's Avatar
with dmm, your safe mesuring 10amps, wich the charger is not using 10 amps
Old Mar 2, 2006
Old Mar 3, 2006
Toaster's Avatar
I do not have anything tapped into the lighter circuit. The only things I have done to this vehicle was a front sway bar and a K&N air filter. None of which have anything to do with the lighter. I will have to try out the battery test.
Edit: Tested with battery. Only about 2 amps. Which is right were the fuse one the chager is rated. Both with and without the pohone plugged into it. Guess the console is going to have to come out.
Old Mar 3, 2006
CraigW's Avatar
I have seen in the past the plug for the device will briefly short out the socket when it is inserted, causing the fuse to blow.
Old Mar 3, 2006
Toaster's Avatar
That is what I was thinking. That is why I tried leaving it in the socket and not taking it out and putting it back in. Still have not taking the thing apart yet.
Update: Sorry to bring this back up but it might help someone. Finally took console apart just to find out charger was shorting. Pluged charger in with the console out so I coiuld see if it was shorting inside. Noticed the charger came apart a bit. So I pulled the two hlves apart and noticed the spring on the side where touching the end piece when it was inserted. Apparently the little piece of plastic that keeps it from doing that broke.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
General DIY
Sep 25, 2015 08:02 PM
Bricoleur
Sep 9, 2015 12:23 PM
hatch90
Sep 3, 2015 08:45 AM
