Speakers go weeeooo weeeoo on acceleration
Old Feb 24, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
i have a manual trans in an 05 civic, and when I start off and the radio is on, my speakers go weee oooo weee ooo, i was told by some friends that i have to do a grounding kit like a hyper volt kit or something to get rid of this sound. Can you please help
Old Feb 24, 2006
Pharoh's Avatar
Bobaganoosh!
mine did that when it was on AM sports radio..not on FM. I just assumed it was the ground. I have a new deck now and no problems....
gonna move to I.C.E as well...
Old Feb 24, 2006
X0DuZz's Avatar
umm....yeah?
X0DuZz is just really niceX0DuZz is just really niceX0DuZz is just really niceX0DuZz is just really nice
i think it is your ground. my speakers do the same thing
Old Feb 24, 2006
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
on your amp: check the x-over: change it to LPF (if you have that option)
:edit: oh wait---do you even have a system??
Old Feb 24, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
it's either a grounding issue with your amp OR the amp does not have very good noise isolation circuitry, which is a very common drawback of lower end amps. What amp are you running?
Old Feb 24, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
i had this problem...check your grounds.... if you bolted your ground wire to a painted metal source you might want to sand the paint down. also check your wire and make sure that speaker wire aren't tangled or too close to power and ground cables
Old Feb 26, 2006
WhiteRabbit's Avatar
we call that "alternator whine"
its generally caused by a phenomena called "ground loops"
there are several cures for ground loops, depending on where the noise is getting into your system.
you can put a power line filter on the radio. its just a big coil.
you can use an RCA filter. its a convinient box that goes inline between the radio and ampifier. seperates the ground between the radio and amplifier, which can cause problems.
you can try regrounding your gear, but its a pain in the ****. if your current grounds arent clean, disconnect them and get a good connection to your frame. if noise persists, I suggest a filter before you start grounding here and there looking for the "clean" one. more work.
Old Feb 26, 2006
cwo715's Avatar
Falken Master
I'm running 2 MB Quart 10" Subs, MTX Blue Thunder Pro 400X5, Polk DB Speakers all around... ill check the ground wire
Old Feb 26, 2006
ramcosca's Avatar
Words on a User Title
Maybe it's the sub-VTEC engaging? (lol)
Old Feb 27, 2006
dont laugh, its not unheard of
around the same RPM vtec kicks in, the alternator voltage sense relay (or whatever the heck its called!) almost always kicks in, and if thats the cause of the noise, then its totally possible to be noise free under 3500 rpm =D
gosh hi-revving becomes annoying, though!
Old Feb 27, 2006
ramcosca's Avatar
Oh, so the subs have VTEC too then? Cool!
So I this doesn't happen on DXs, does it?
Old Feb 27, 2006
chriscivic's Avatar
chriscivic is an unknown quantity at this point
would someone(whiterabbit) please make a diy on how to have sub-vtec on dx/lx models. please, i want my speakers to go "weeeeooo weeeoooo" while i accelerate a high rpms. seriously
Old Feb 27, 2006
ramcosca's Avatar
Old Mar 3, 2006
cwo715's Avatar
Falken Master
now it only happens when the lights are on, when the lights are off, there is no whine
Old Mar 3, 2006
could be either induced noise from the headlights, or more likely a ground loop between the stereo and the headlights.
try a powerline filter on the 12 volt constant wire of your radio. if you can't find one, see if you cant just find any old inductor. you could even go to an audio shop and ask if they have any spare passive crossovers laying around that you could buy for $5. itll have an inductor you can gut out and use (hell, you could just use the whole "lowpass" section if you wanted! but just the inductor should suffice.)
UltraHDGames
Jun 8, 2016 05:16 PM
Bruce2
Sep 27, 2015 08:45 PM
Gsxtacy
Sep 12, 2015 01:09 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
dantheman42
Sep 4, 2015 01:10 PM
