Axle??
Old Feb 17, 2002
MyCivic's Avatar
MyCivic is an unknown quantity at this point
Axle??
So I cut the power steering belt bout 4 monts ago for th powe gains ( I say it give more then an intake, plus u get a work out ) now iam hearing a noise in the left front tire each time I make a sharp turn - mostly under 20 mph - I think I need to put the belt back on and head to the dealer, what do u guys think it can be??
Old Feb 17, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
What kind of noise is it exactly? If it is a clicking noise, check the boot around the CV joint. If it is ripped you may have a bad one. They usually don't go for a long time though. Cutting the belt should have no effect on the steering components, besides not being able to turn so easily at lower speeds. Let me know what kind of sound it is and I'll try and help!
Old Feb 17, 2002
MyCivic's Avatar
My fault mn, acctually it is a single klick. Like something brakes or hits something. It is not repetetive, whe I am turning hear it once and that is it. And it anoys the crap out of me, and I need to fix that stuff cause Venom is waiting to be put on [IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 18, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
http://www.7thgencivic.com/forum/messageview.cfm?catid=36&threadid=24322 ...check out this thread and see if it helps you.
Old Feb 18, 2002
Rebew1's Avatar
It sounds like it could be a CV joint. Is anything hanging loose down in that area. You can also get under the car and move the axle up and down side to side to see if it has any excessive play in it. Check the boot first for any cracks or grease seeping out.
Sep 26, 2023 06:44 PM
beanhead
Sep 24, 2015 12:04 PM
bashea
Sep 15, 2015 04:59 AM
logsplitter1
Aug 9, 2015 09:32 AM
califcamper
Jul 21, 2015 10:34 PM
