how many miles is to many miles to turbo
Old Jan 29, 2006
unforgiven_nite's Avatar
unforgiven_nite is an unknown quantity at this point
ok this has just been a question on my mind that hasnt been answered yet and i hope somone out there can give me there opinion.....how many miles is to many miles to turbo charge my d17?? right now i am sitting at 93k
Old Jan 29, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
that concerned me to i have 103,000
Old Jan 29, 2006
i thought about getting a new or alot less mile d17 and turbo that!??
Old Jan 29, 2006
v8eaterokv6's Avatar
i have a new home do u
i had 73xxx on mine when i went turbo i now have 75xxx and have blown the head gasket once. take my experience as you wish. im not saying one or the other.
Old Jan 30, 2006
turboengnr's Avatar
DONT PANIC
i turbod my CRX when it had 265,000 miles on it. It lasted until 305,000 miles, but it broke because i was greedy. 20 psi of boost is a little much to ask of a stock single cam.
Old Jan 30, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Milage doesn't matter as much as how much compression and blow by there is.
Get a compression/Leakdown test done, see if the motor's still healthy
Old Jan 30, 2006
iamboo's Avatar
Retired - SoCal FI Mod
honda motors are built to last forever as daily drivers...
bolt on a turbo kit and being a lil more careful about the up keep on the car will keep the motor running strong...
Old Jan 30, 2006
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
^^ wut they said, from what ive hear u might also want to look into getting most maintanence work done before u slap one on there. Like getting a compression test,^^ get ur headgasket replaced while also getting the timing belt and water pump replaced. Just my 2cents, i got just as many miles as u do and my compression is still perfect. Now i just need to find my ***** and get this thing on there.!
Old Jan 30, 2006
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
i have 100k with turbo
Old Jan 30, 2006
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
Id like to do one as soon as mine is off of warranty. It only has 3500 miles so far lol.
Old Jan 31, 2006
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
when you have so many miles that you have rods knockin or your rings are shot so bad you're changing oily plugs every other day then you have too many miles to turbo but not until then
edit: of course I'm exaggerating a lil but, its mostly true....doesnt matter how many miles as long as the engine is in good working order.
Old Jan 31, 2006
HyaBoosta's Avatar
i boosted mine with 90k and now I have 111k and never had a problem. 10psi
Old Feb 1, 2006
Matulin407's Avatar
hope it stays that way HYA^ i hope i dont get any problems either, but my luck sux.
Old Feb 1, 2006
ok well all that helps. can any mechanic do a compression leak test or should i go to the honda dealership and have it done? as a matter of fact, im getting new clutch, possible sychros or possible new tranny. should i as them to do a compression test?? its still under powertrain warranty till 100k, think they will do it for free?
Old Feb 1, 2006
oh and if my compression is bad or low what can i do to get it back to normal??
Old Feb 1, 2006
an overhaul...
Old Feb 4, 2006
puidokas's Avatar
would it be wise to keep the boost to 4-5psi with over 100,000 miles
Old Feb 4, 2006
there is your answer. if the compression is too high due to not taking care of the motor (carbon buildup), then it increases the amount of problems you'll have later on.
Old Feb 4, 2006
puidokas's Avatar
I can swap a engine myself, would it be cheaper than a overhaul
Old Feb 4, 2006
well yea get a low mileage engine on ebay for $400 and do the install yourself. its either that or tear up the old engine if you know how then its a tossup of how much work you're willing to do.
Old Feb 4, 2006
puidokas's Avatar
work isnt the problem, its the money
Old Feb 5, 2006
TQ_'s Avatar
TQ_
TQ_ is an unknown quantity at this point
I don't know much about your budget and I may of missed you stating how much you was looking to spend. If I was you, since your motor is already at 93k I would save a little more money then build the motor up. That away when you boost it, you can turn the boost up a little on a safe tune and enjoy it.
Old Feb 15, 2006
straightfaced's Avatar
straightfaced is an unknown quantity at this point
Turboed at 135,000km
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
mikevtec
May 3, 2015 01:36 PM
civiccowboy
Nov 19, 2001 03:44 PM
