gauge questions..
Old Jan 23, 2006
ill02civic's Avatar
ill02civic will become famous soon enoughill02civic will become famous soon enough
Question gauge questions..
i have a boost gauge already..but what other two gauges do you guys suggest on turboe car ?
Old Jan 23, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Anything that there's room on the dash for thats related to the motor.
Old Jan 24, 2006
ill02civic's Avatar
oh arrite ... well i have a three gauge pillar.i have a boost gauge...and planning on getting a water temp gauge and iono what else ..ha..
Old Jan 24, 2006
tfnaaf's Avatar
BLDNPSI Mod
Wideband AFR meter
Old Jan 24, 2006
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
may want to consider a egt gauge. (exhaust temp)
Old Jan 24, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
I have Defi boost, oil pressure, egt and AEM wideband a/f.
Old Jan 24, 2006
diskreet's Avatar
quick o/t ?:
what is the importance of EGT gauge? why do people recommend them?
roughly what is too hot and what can cause that?
thanks to whoever clears this up for me.
Old Jan 24, 2006
dezod's Avatar
7thgen Power Maker
Originally Posted by diskreet
quick o/t ?:
*chime*
You should monitor EGT's with a WB O2 to determine best torque without EGT's raising and power falling off. Once you determine lowest EGT and best power, you can now match the same A/F in any other time in the RPM bad easier now.
Edit: With a wideband you getting half of the combustion full picture. Coupled with an EGT, now your getting all of the info
REMEMBER TO REP!
Old Jan 24, 2006
dezod's Avatar
7thgen Power Maker
If you need/want oil pressure or oil temp.....we have both in stock and cheap!
http://dezod.com/cat_inventory.cfm
Old Jan 24, 2006
diskreet's Avatar
thanks dezod. repped.
Old Jan 24, 2006
ill02civic's Avatar
tenx for the help peopl.. whats an egt gauge ? so is this good enough ..i have a boost gauge...water temp ... and i need one more..im guessing the egt gauge..which is what ?
Old Jan 24, 2006
dezod's Avatar
7thgen Power Maker
Exhaust Gas Temp
Old Jan 24, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
get wideband and egt
Put the money you were going to spend on the water temp toward wideband, prob the best gauge to have besides boost gauge.
edit:You already have water temp? get the wideband before egt
Old Jan 24, 2006
Jap-Euro Fusion
This is more a forceful bit of encouragement more than a flame, so will you PLEASE figure out what the hell it is you're doing before you do it. Its very obvious from the 3 threads you started on the subject you know little to nothing about turbos, and its a pretty dangerous place to be in if you're trying to boost an engine. Ignorance and stupidity aren't solved by throwing money at the problem, your turbo specialist at your buddy's shop isnt gonna fix your car if it breaks on the side of the highway, nor is he going to know the ins and outs of your car like you would if you knew what was going on yourself. So you better figure out what you're doing before you install that thing. None of these complete bolt on systems are complete, there's lots of little details to know about and if overlooked basically spell disaster.
Get the book about turbos by Corky Bell. Read the entire turbo FAQ, and read some of the turbo FAQs elsewhere on the internet before you even begin to think about starting to look at the possibility of trying to bolt this thing on.
You'll thank yourself when you're not picking up the rods off the road, or cleaning oil out of the entire engine bay.
Old Jan 24, 2006
jackburton's Avatar
Yeah if you goto borders there will be like 3-5 books on turbo and supercharging cars. There are also other tuner books that have soem good information. there is also a book on tuning the aem ems, which i have yet to be able to sit and read through. I keep putting it off, cause it is so complicated to learn.
Old Jan 24, 2006
pon55's Avatar
GOD has spoken, well maybe hes not god but he is one of the most intelligent people on the form!
Old Jan 24, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
id say a wideband a/f is a MUST for you because you obviously arent aware of whats going on so as long as you understand what an air/fuel mixture is you can atleast tell if your turbo/fuel system is completely messed up.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
