I've searched but still need help on: SRS Light
Old Jan 4, 2006
Juancho007's Avatar
Juancho007 is an unknown quantity at this point
Hello everyone,
I've been having a bit of a problem with my SRS light. First time it came on, I reset it myself using the DYI then it came back on after a couple of days. I took the car (01 Civic LX Coupe) to the dealership, they ended up replacing the ODPS? unit and the battery saying that it was malfuctioning and that the battery was low or something like that. A few days after that the light came back on and I took the car in again, they said it was the same thing (interference from another electronic device in the passenger seat) and replaced the ODPS unit again under parts warranty from the first one. They told me not to let anyone use anything such as a laptop in the car, especialyl in the passenger seat because it would trigger the SRS unit. Today, one day after the second replacement of the ODPS unit, the light came back on with only my cell phone in my pocket as an electronic device that could possibly cause interference. The only other thing that I can think of is my radio a Kenwood Excelon x869 but it has never given me this problem in the 2 years Ive had it. Does anyone have any other suggestions???? Please help I am frustrated and Im afraid the only thing Honda will do is replace the unit again and again until I sell my car.
Old Jan 5, 2006
jttegx's Avatar
OMNES AD UNUM
take it to an shop that can permanently get rid of that issue rather than the dealer. if not that, demand to have honda replace your vehicle with a legit one. but seeing that you're an 2001...not sure on that last one.
Old Jan 5, 2006
eklipz's Avatar
LOL you could do what i did and put a peice of cardboard behind the cluster...
Old Apr 4, 2006
stylesabu's Avatar
stylesabu is an unknown quantity at this point
check your running battery voltage, mine keep coming on and it turned out to be alternator overcharging.
Old Apr 4, 2006
diskreet's Avatar
HOW TO RESET SRS LIGHT:
http://www.7thgencivic.com/forums/sh...d.php?t=155251
Old Apr 4, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Check as well that all your airbags are properly connected. If you have a disconnected airbag or one with bad wiring your SRS light can keep coming on even though a reset will temporarily turn it off. I had this problem in my car, turned out one airbag plug was disconnected somehow.
Old Apr 4, 2006
diskreet's Avatar
for me it was unplugging the seat belt signal wire under the seats while the battery was connected. if they disconnect again you will need to reset again. def check all your connections
Old Apr 4, 2006
e04241's Avatar
e04241 is an unknown quantity at this point
nice solution
better not yawn inside the car as well
are you still within warranty?
Old Apr 4, 2006
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
Did anyone use a paper clip for the DIY? Will it actually work?
Old Apr 4, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
yes a paper clip works splendidly
Old Apr 4, 2006
...ever grinning...
Ok cool. Because ever since I put Tenzo in it's been annoying the crap outta me.
Old Apr 4, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
i used an antenna wire that came off my home stereo system nd it works great. i would say just find any kinda of speaker wire and use that. its easy as dump...sorry nyquil is kicking my butt right now so some things might not b clear.
Old Apr 4, 2006
ironchef's Avatar
There is no substitute
ironchef is an unknown quantity at this point
the whole srs system can be a pain in the ***. I had my SRS light turn on after my cable reel (the contacts attached to the steering column) was damaged. The system read it as my airbag being disconnected. If your cable reel isn't making proper contact (intermittent problem) it might cause your light to come on.
Sounds like the dealership is just replacing stuff and making up excuses since they can't properly diagnose the problem. There's no way that a head unit, cell phone or laptop should cause those problems.
Maybe it's time to take it to a different stealership.
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
SimDogg
Nov 27, 2001 04:20 PM
