Sway bar Noise is too much
Old Jan 2, 2006
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
Angry Sway bar Noise is too much
Here is the deal,
about two months ago I had noise coming from my progress front sway bar, and it was crazy loud. So I finally took the bolts securing the poly bushings off and lubed up the bushings with silicone grease. I did both the front and rear sway. It sounded fantastic!! No noise what so ever. Today the noise is back and bigger than ever. Obviously the grease i used wasnt the right type, so question is what is the right grease to use?
I also have an idea that would probably half work. there is this stuff called teflon tape used in the plumbing industry to seal screw type joints. If there was a way to install this tape and prevent it from squeezing out from between the sway bar and the poly bushing I think this would be best. So question is what will hold that teflon tape in there? Keep in mind that the teflon tape is not sticky so it wont adhere by itself.
Old Jan 2, 2006
tell me tell me tell me. somebody just tell me what grease will work and last long time....
Old Jan 2, 2006
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
Lithium grease works the best. Comes in a can or jar and it's about 7 bucks.
Old Jan 2, 2006
Aight!
I will post my results one day with the lithium. But remember guys, 100% silicone grease is worthless for this application.
Old Jan 2, 2006
D5cIvIc's Avatar
how long did the orginal grease you used last for?
Old Jan 2, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Find something that says "Marine" or "outdoor use" or something to that effect.
Marine grease is best because its designed for water use.
Old Jan 2, 2006
CivicSF's Avatar
CivicSF should not be trustedCivicSF should not be trusted
most lithium-based greases are high-quality EP level 2 lubricant, which is what i use in 1000+ hp domestic hot rod applications (drivetrain parts).
Old Jan 2, 2006
Civicman1988's Avatar
totally agree
Old Jan 2, 2006
About a year and a half, but I forget what kind it was. It came with the sway bars.
Old Jan 2, 2006
cool, I will be looking for this stuff. Seems like you should know with your experience.
Old Jan 2, 2006
D5cIvIc's Avatar
why not just save money and keep on lubing it every now and then with the grease you already have
Old Jan 3, 2006
The last greasing only lasted a couple months, so I dont want to redo the grease 6 times a year. If I had grease fittings then I might consider it. Plus, I ran out of this type of grease.
Old Jan 3, 2006
CivicSF's Avatar
real grease keeps you on the road. shitty grease can cause shhit to fail. think about being 3 hours from the closest town to bumfuk, whereever, and having your axle about to fall off cause you use shitty CV grease 30k miles ago and didn't maintenance it since. that'll get you using EP greases mighty quick.
Old Jan 5, 2006
P40vic's Avatar
P40vic is an unknown quantity at this point
Here's a technique I read about that some off-roaders use with poly bushings. Rough up the inside of the bushing with some sandpaper (80 grit worked for me) then install with whatever grease you choose. Worked great for my rear ES bushings. My thinking is that the bushing can only squeak if it has a large smooth surface in contact with the bar. I noticed that H&R bushings have some sort of weave on the inner surface of their bushings, I would assume for the same reason.
YMMV however.
Old Jan 5, 2006
simplicated1979's Avatar
simplicated1979 will become famous soon enoughsimplicated1979 will become famous soon enough
i think it's not that much i got one
Old Jan 5, 2006
YMMV however.
Dammmit, why didnt i think of that? This sounds perfect, it has to work. The surface of my bushings are so smooth its ridiculous.
THX
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
muniorbust
33
Aug 31, 2015 08:59 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
