End Link Questions-just a couple
Hey guys,
I got greys end links in yesterday and put them on. They are awesome. I just have a couple of questions. The car is still bouncy in the rearend. Not as bad as right before the stock links blew out. But just a little bit. Is this normal?
Also, The top ball joint is angled up as far as it can go I think. Is this normal or should it be straight? I couldnt figure out a way to make it straight. I have only about two threads showing on the male and female part that screws together. Should I unscrew it some more and make it straight or will this not do anything?
thanks for any help you guys can give me.
Realitycheck
Realitycheck
Unthread the link to make it longer. The rod ends should be at 90deg. to the link at ride height. I am assuming you have a progress bar? Oh yea, make sure you still have a decent amount of threads still in the female end, otherwise it will strip out.
WKD DRGN
Jun 18, 2015 07:56 AM
mrohitredd
Jun 9, 2015 06:37 AM
zcwagon
Apr 24, 2015 05:18 PM
CapYoda
Nov 29, 2001 07:37 PM
