is it too late for the MIL eliminator?
Old Dec 21, 2005
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
so i've been having my check engine light on for about a month now, due to the aftermarket header i put in...so recently i noticed that my car has lossed ridiculous amount of power, its really slow, and its eating gas like CRAZY, u can literaly see my gas go down,so i was told its cuz the check engine light, so im basicaly just waiting for it in the mail, but is it still going to work?
Old Dec 21, 2005
does any1 know?
Old Dec 21, 2005
HiVtec's Avatar
HiVtec is an unknown quantity at this point
do you have ex or lx?
Old Dec 21, 2005
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
if you have time replace the stock header and see if that does anything and if it doesn't take it to the dealer
Old Dec 22, 2005
i have an LX, and the guy i bought the wires from, he says when the check engine light is on, that it puts the computer in "default mode" and it affects ur AIR/FUEL ratio, and also affects timing, which makes sense, so i think its cuz of the CHeck engine light, and that light is on cuz of the headers
Old Dec 22, 2005
HiVtec's Avatar
my car is ex and I resolved this problem with the Spark plug non-fouler trick!
Old Dec 22, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
^ what trick?....explain please!
Old Dec 22, 2005
HiVtec's Avatar
go to this website
forum.2gn.org/viewtopic.php?p=9464&sid=2855dcaa177392cce734dda15 3f051d0
the best thing obout this is the cost, around $7.00
Old Dec 22, 2005
HiVtec's Avatar
other site
s2ki.com/forums/index.php?showtopic=229959&hl=simulator
Old Dec 23, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
yeah the spark plug fouler works instantly, once u put it on it drive couple miles and cel should turn off. Ive only seen it work on ex exhaust systems where the cat is located on the bottom of the car, but Im sure itwould work for lx models as well. Just make sure u fouling the right sensor that detects the cat only and not the primary sensor
Old Dec 23, 2005
well, i'm not sure if im familiar on the ex sensors are located, but on an lx, their is one on the top of the manifold, than it looks like the cat, and THAN the secondary sensor, and i'm thinking its the secondary sensor that picks up the CEL.
Old Dec 23, 2005
that nonfouler thing, im not too sure i understand it 100%
Old Dec 23, 2005
HiVtec's Avatar
when you put an aftermarket header in your lx you take of the cat and bolt the secundary o2 directly to the header, What I found in the web was that you can't bolt the secundary o2 directly to the exhaust because is going to reed to much A/F mixture and the Fu*&(^ check engine light comes alive, that's when the non-fouler comes to separate the o2 from the exhaust.
Old Dec 24, 2005
yea i get that, but on the non fouler, u drill it half way down so it can be thinner or what?
Old Dec 24, 2005
HiVtec's Avatar
the none-fouler comes with 2 parts one of them you have to leave stock and the other one bore out w 1/2 drill. The o2 goes to the one you drill and the stock one to the exhaust.
go to this link:
Old Dec 25, 2005
hmm the secondary sensor doesn't affect the a/f ratio. maybe the engine light is causing it. but try the mil elim anyway and see.
Old Dec 26, 2005
well yea, the seconday one doesnt affect any, it just makes the engine light turn on cuz the secondary sensor is reading different air, so by the CEL coming on, thats what affex it, since it puts my computer on "default mode" thats why, hey but what do u mean the other stock non fouler goes to the exhaust? for an LX both sensors are on the header itself, can some1 draw me a sketch, or something, sorry for being such a noob at it, but when it comes to doing something "exact" i dont wanna screw up
Old Dec 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
take the first fouler and drill it out to .5". Then screw it on to the sensor, then screw on the second fouler then screw it into the secondary O2 sensor location....
Old Dec 26, 2005
so the mil eliminator, those are wires that connect to the sensor wires? if so, i'd much rather choose doing the nonfouler, by not messing withthe wires or whatever
Old Dec 27, 2005
VietScouty's Avatar
VietScouty is an unknown quantity at this point
I have the mil eliminator on mine. But what I was told by the tuner shop, its a resistor unit that bypasses ****. As for gas mileage, since I got a VP/DX, I manage to maintain a total of 420 miles with lesser than a gallon left in the tank. This includes with 215/35/R18 wheels, CAI, headers, and axle back exhaust. But then again, I had done some weight deduction to my car such as back seats and some other stupid heavy weight components.
Old Jan 7, 2006
i tried the mil eliminator, it didnt work, so now im gonna try the non fouler, but do i need 8mm non foulers, or which size? and should i just leave the eliminator connected to the sensors or should i take it off??
Old Jan 7, 2006
tfnaaf's Avatar
BLDNPSI Mod
look bellow my signature
Old Jan 8, 2006
what do u mean???
Old Jan 8, 2006
tfnaaf's Avatar
BLDNPSI Mod
I mean follow the link below my signature!
DIY Mechanical O2 simulator
Originally Posted by White0nGold
what do u mean???
solarpunk70
Apr 12, 2016 11:43 AM
Sep 27, 2015 11:33 AM
MamaBear2015
Sep 15, 2015 09:35 PM
MamaBear2015
Sep 7, 2015 06:00 PM
Hrddrvs
18
Aug 17, 2015 01:08 PM
