02 sensor causing bad gas mileage?
i have a faulty 02 sensor and im only getting like 30 mpg with a mix a city and highway.. i would like to be getting 40+.. the last full tank i had i only did like 330-340 miles per tank.. will the 02 sensor do it?
if you have a faulty o2 sensor, your check engine light will be on.
Now I dont think you have a faulty 02 sensor. I get about 30 MPG with mostly all highway miles. ANd I also get about 330 to a tank. You arent going to get 40 MPG, maybe once in a good while, but its hard.
Now in general, yes a faulty 02 sensor can cause a decrease in mileage. If the sensor is reading too lean, the ecu will think you are getting too much air and will increase fuel. But again, a faulty one will usually throw a check engine light.
tylerginevan
Apr 27, 2015 12:29 PM
