refilling atf
Old Nov 11, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
refilling atf
so i have a question, how do you guys reach the spot where youre supppose to refill the tranny with honda atf. its like a foot down on the left side of the engine bay. im thinking about using a funnel and a plastic tube. any suggetions?
Old Nov 11, 2005
soltex's Avatar
soltex has a little shameless behaviour in the past
yeah something like that. Hey where did you get the Honda ATF fluid. DO they sell it at autozone>????
Old Nov 11, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
transmission fluid bong (funnel and hose)
Old Nov 11, 2005
zen_master's Avatar
you definitely need that bong...
get the ATF from honda dealer ONLY...
Old Nov 11, 2005
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
yep, exactly. i took a regular transmission funnel [cuz it wasnt long enough] and cut about 1/2" off the end so that i could squeeze a 1/2" tube through it while keeping it quite tight, really quite tighter than I normally like it. I used about 12" of 1/2" tube, ok, so now the tube reached the filling inlet to the transmission. I just poured it in!! yep, and I used genuine Honda ATF.
Sometimes you gotta just make this sh!it up Mr. Chowmein.
Old Nov 11, 2005
soltex's Avatar
How much would they charge,??
Old Nov 11, 2005
I paid $6.75/QT at Roush Honda in Westerville, Ohio. Then they charge tax.
Why can't they charge less $?
Old Nov 11, 2005
mrchowmein's Avatar
i bought honda atf-z1 from ebay. i had a coupon. paid $48 with free shipping for 12 quarts. not uber cheap, but cheaper than dealer.
Old Nov 12, 2005
soltex's Avatar
Dammm,
how much would an auto tranny needs. How many quarts.
Also how much would a shop charge to change tranny oil?
Old Nov 12, 2005
honda charges $50 including the oil. not bad.
Old Nov 12, 2005
mrchowmein's Avatar
thats for one change right? not for a full flush which takes 12 quarts right.
its like a more expensive oil change basically for honda.
Old Nov 12, 2005
one change. they don't recommend a flush because it damages certain components of the transmission.
Old Nov 12, 2005
mrchowmein's Avatar
i think we are talking about two different methods of flushing. im talking about the flushing honda recommends in the manual: "to thoroughly flush the trannsmission, the technician should drain and refill with Honda atf-z1 then drive the vehicle a short distance. do this 3 times then drain and refill the transimssion for the final time" and not the pumping of a cleaning agent throught the tranny method.
this is on page 220 of the 02 civic manual.
Old Nov 12, 2005
ya but they only do it once. Thats why I have it changed every 10k, so there's always new fluid in there.
Old Nov 12, 2005
mrchowmein's Avatar
i see i see. i guess that works too.
Old Nov 14, 2005
grapehead's Avatar
grapehead is an unknown quantity at this point
what do they say a regular flush will damage? i did mine about 10k ago, with regular atf + additive rec for honda. all fluids + any damage that would be caused by them are warrantied by the company we get our machine and additives from.
no problems yet...
Old Nov 14, 2005
including a dead tranny? wait and it will happen. if the flush is done properly, then maybe you'll be fine IF you used honda atf. so you prolly won't be fine.
Old Nov 14, 2005
grapehead's Avatar
yeah, including the tranny if it bites it.
what are you basing this off of? i mean if anything besides honda atf caused them to fail i would think there would be a bulletin to shops using everwear produts and machines.
Old Nov 14, 2005
the honda atf is specially formulated with small molecules. the tranny is very sensitive and other fluids might not be able to lubricate as well. i know someone who flushed their tranny with mobil1 and 40k later the tranny was broken completely.
2002ExCivic
22
Sep 28, 2015 08:29 AM
4jacks
Aug 17, 2015 01:26 PM
Drix
Aug 14, 2015 11:41 AM
Doug Lassiter
Aug 9, 2015 09:31 PM
Q-Bert
Jul 19, 2015 09:09 PM
