tuboing new engine
Old Oct 8, 2005
kornsined's Avatar
tuboing new engine
I'm planning on turboing my k20a3 but It's pretty much a brand new engine. It has only 180kms on it. My plan is to have it installed and tuned with the turbo all at the same time. I'm not sure though if i should break it in at low boost or would it really matter. I want this thing to be reliable so i'm thinking 8psi but now i'm not sure if i should be worried about wrecking the engine because it's not broken in yet.
Old Oct 9, 2005
civic01vtec's Avatar
If it was me, i wouldn't boost it until your first oil change. If you are gonna boost it now, just run low boost and don't jump on the throttle until your first oil change.
Old Oct 9, 2005
Havok2k1's Avatar
Wicked Pissah Admin
I would give it a good thousand miles for the rings to set before you start running boost. Boosting immediately on a motor that doesn't come with blower rings from the factory could lead to premature ring blowby...
Old Oct 9, 2005
kornsined's Avatar
damn that sucks because i want to install it all at once to save some cash.
Old Oct 10, 2005
duck13's Avatar
duck13 is an unknown quantity at this point
engine break ins? isn't that more like a thing of the past? as far as I know... motors nowadays don't need it...
Old Oct 10, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
lol, bikes need them thats for sure, i would assume that so would a soon to be turbo'ed motor would too
Old Oct 10, 2005
HondaLuver's Avatar
Its a celebration bitches!
trust me, a engine needs a break in, i got my car tunned, and it had less than a couple thosand miles, i got it tunned... i had to get it retuned, and i got 14 more hp from the same machine and tuner
Old Oct 10, 2005
kornsined's Avatar
so can i still install the turbo and run like what, 2psi without any damage? As long as i drive it lightly for the first 5000kms.
Old Oct 11, 2005
zach_04LX's Avatar
zach_04LX is an unknown quantity at this point
Yeah, you can get the turbo installed at the same time, but make sure to set your boost low. I would drive it at no more than 1-2psi for the first 5000km, and don't open it up.
Old Oct 11, 2005
Well, i hate to tell you.........depending on your wastegate spring......you prolly won't be able to run lower than 4psi. Are you internally or externally gated ?
Old Oct 11, 2005
kornsined's Avatar
looking at a greddy kit so internal...
Old Oct 11, 2005
Then you can disconnect the wastegate actuator rod and run 0 psi.
Old Oct 11, 2005
kornsined's Avatar
ok cool. yeah I'm getting a greddy kit with intercooler and kpro. I'm excited.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
