For those ppl with emanage......
Old Oct 6, 2005
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
Question For those ppl with emanage......
I am having stalling issue if i put the gear into natural too fast. I have to leave the gear in as long as possible before the car stop, otherwise, the car will just stall. My question is, for the ppl with turbo that are using emanage, any of you have this problem?? I currently have safc with type s injectors and am about to switch to emanage. just want to know if emanage can fix my problem or not. If not, i might just get aem ems. thx a lot
Leon
Old Oct 6, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
sounds to me like you're running rich.
Old Oct 6, 2005
leonhsieh's Avatar
i was thinking about that too before. But i pull almost 30% of the fuel out at low rpm. I also get it dyno tuned. The problem is still there.
Old Oct 7, 2005
tfnaaf's Avatar
BLDNPSI Mod
re-learn idle yet?
Old Oct 7, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
when i had the safc i pulled 35% out of idle range
Old Oct 7, 2005
Blahman240's Avatar
let me get this straight, narrow throttle is idle? Then whats wide throttle? I know nothing, inform me.
Old Oct 7, 2005
Blahman240's Avatar
btw, I'm talking about with the vafc2, but should be the same with safc
Old Oct 7, 2005
leonhsieh's Avatar
idle is fine. it is just when i take the gear out too soon. it will stall(while the car is moving). i tried 35% at low rpm before as well, the problem is still there. i pretty much tried everything i could with safc. I just want to know will emanage sovle this? any of you with emange have this kind of problem?
Old Oct 7, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
whats your RPM's at idle?
Old Oct 7, 2005
leonhsieh's Avatar
from what safc says...700 without any load...i tried to raise the idle as well. it doesn't work..
Old Oct 8, 2005
Try to rase idle to 800+ and see if it helps....
Wariogamer
Sep 29, 2015 09:49 AM
Gocoolean
Apr 18, 2002 08:01 AM
eXNBP
Mar 8, 2002 09:02 AM
klectic
Canada West
Mar 5, 2002 10:01 AM
ricerocket
Mar 4, 2002 07:55 PM
