For those ppl with emanage......
I am having stalling issue if i put the gear into natural too fast. I have to leave the gear in as long as possible before the car stop, otherwise, the car will just stall. My question is, for the ppl with turbo that are using emanage, any of you have this problem?? I currently have safc with type s injectors and am about to switch to emanage. just want to know if emanage can fix my problem or not. If not, i might just get aem ems. thx a lot
Leon
Leon
idle is fine. it is just when i take the gear out too soon. it will stall(while the car is moving). i tried 35% at low rpm before as well, the problem is still there. i pretty much tried everything i could with safc. I just want to know will emanage sovle this? any of you with emange have this kind of problem?
Originally Posted by leonhsieh
from what safc says...700 without any load...i tried to raise the idle as well. it doesn't work..
ricerocket
Mar 4, 2002 07:55 PM
