check engine light P1457 Evap. bypass solenoid valve
Hi. my check engine light came on and it ran up as a P1457, which is the Evaporation bypass solenoid valve. I need to replace it but the thing is i brought my car to the mechanic 7 months ago and they had to replace the vent solenoid assembly and the charcoal canister(they gave me no codes). is the vent solenoid and charcoal canister the same as the evap. bypass solenoid valve, or is it different.
Thank you
jdfrock2003
Thank you
jdfrock2003
that code means EVAP control system Leakage (EVAP canister system). The canister is different from the solenoid valve. the charcoal canister stores fuel vapors untill they can be burned by the engine. The solenoid valve opens to bypass the two way valve when doing a leak check. Now this code doesnt necessarily mean your solenoid valve is bad, you need to diagnosis it to find the cause. Now if it was in the shop for these EVAP repairs and now there is another one, I would take it back to them and have them check it out. Otherwise if you have a vacuum pump and a DMM I can guide you though on what to check.
I do have the vacuum when i open the gas cap( you hear a lot of air coming out). I did bring it to honda today and there the ones who told me it was the evap bypass solenoid valve. so i'm sure that has to be it.
Hello.
I also recently got a P1457 code and I know it has to do with the EVAP system. However, when I took it to honda for the test, they determined that I need to replace Purge Control Valve, which is associate with the emission system. I tried long and hard to find any association between the P1457 and the Purge valve but couldn;t.
Basically, I want to know if replacing this valve will fix the problem, or honda is simply ripping me off?
Thanks in advance.
Michael
Thanks in advance.
Michael
Originally Posted by mishka_12
Hello.
Thanks in advance.
Michael
Thanks in advance.
Michael
Thank you for your reply. So, is there no way to figure out exactly which valve is causing the light to come on, unless I replace them one by one? Can I drive with it for a while or am I risking causing some major damage to the car?
THanks,
michael
THanks,
michael
THanks,
michael
THanks,
michael
Now you arent hurting the car by driving around, however you EVAP system isnt working correctly and you may be producing harmful tailpipe emissions. You wont pass inspection untill you fix the problem.
Thanks very much. Seeing how I need to change my license plates since I moved to a new province, I probably will go ahead and replace the purge valve. However, from what I understand, I may still have the same problem, because, as honda said in their form, "other valves may be replaced".
my check engine light came on and it ran up as a P1457, which is the Evaporation bypass solenoid valve. I need to replace it and i was wandering if it effects the fuel mileage on the car cause i've been getting bad miles to the gallon. I also got the vent solenoid replaced and canister 6 months ago. is that different then the evaporation bypass solenoid valve.
And yes the solenoid valve is different then the charcoal canister and vent valve. I am not too familiar with the vent solenoid though so not too sure on what its responsibility is.
Honda P1457 ODBII code
There is a TSB (Techniscian Service Bulletin)out from Honda on this issue, 03-001. See this link for more informaion on the problem.
forum.mpt.org/messages/9/6923.html?1130245981
This seems to be a big problem with Honda, but there is no recall in sight on this issue.
The problem usually lies with the Purge control Solenoid valve in the EVAP system. If you live in an environment where salt is heavily used on the roads in the winter, the salt gets into the part and corrosion will cause it to fail. If this problem gooes on too long it can possibly cause the ECU to short out, a quote from a Honda dealership referenced in the link above. So long term damage can be done. The re-engineered part only costs between $50 and $65 and is fairly east to replace yourself.
Mark
Mark
Re: check engine light P1457 Evap. bypass solenoid valve
Hey, i know this thread is kinda old. But i have had a P1457 code on my 99 honda prelude for a long time. I havent had money to fix in for awhile and i want to try to fix it myself. The car has ran perfectly fine, but the only symptoms i can tell is that i never have any pressure when i open the gas tank. Not to meniton i want the CEL to finally go away. Please help? i cant even find the location of the vent solenoid or the charcoal canister on my car and i cant find any diagrams
I can respond with confidence as I just repaired 2 Civic's in the last 5 months with P1457 error code. This is a 95% probability.
You need to order the Bypass valve Part # 17310-S5A-L31 (2001 to 2005 Civic) It ranges from $35 to $80 depending on who and where you buy it. I noticed the original valves were manufactured in Mexico.
To change the valve, remove the one bolt located above the valve location. ( Use a 12mm socket - 1/4" or 3/8" drive, with a 10 " to 12" extension to reach the bolt). Then wiggle the canister towards the passenger side until it's slightly free. The driver's side of the canister has a slot that mates with a wide tab. Unlatch and unplug the red electrical connector from the Valve; then remove the large 1/2" black hose from the Valve and canister body clips; disconnect the 1/4" black vacuum hose from the top side of the valve. Now the fun part...gently manouver the canister to gain access the large vacuum hose from the top of the canister. Finally, gently squeeze the grey retaining ring at this connector. It will disconnect and the canister will release.
Now you have the charcoal canister and valve assembly in your hands. Good luck removing the two screws from the valve as they are 99% likely to be rotten and break. I suggest to simply drill or grind the screw heads off, and pull off the valve. (Take note of the O-ring attached)
You can install the new valve, using the left over screw shanks as a guide. Clean and extenally silicone-glue the mating surfaces to hold the valve in place. It's not going anywhere as it's reasonably secured to the canister with all the hoses connected. Reverse procedure to install; then erase the Fault Codes with an OBD2 analyser.
This thread is 7 years old. Please create your own thread describing your problem and what exactly you have tried to do to fix it
My solution was to drill out the screws, which also pulled out the threaded inserts. Filled both holes with 2-part epoxy and let it cure for 24 hours. Then I drilled two pilot holes and used two short screws to hold the valve in place.
KevinMCody
Jul 1, 2017 12:59 PM
tombgoodu
Jun 12, 2003 10:32 PM
