Header Install
Old Aug 31, 2005
htuner34's Avatar
htuner34 is an unknown quantity at this point
Header Install
I recently bought oversized headers for an 01 civic ex manual. I've been told several different things when trying to find out how to install the 4 into 1 header. I was first told that I would "have to undo the motor mount in the front and slide it through the bottom where the motor mount was". Then I was told that "i may be able to twist and turn the header to fit through, and that i may have to remove the radiator and fan or maybe just the fan". I bought an off brand called focus Z a buddy of mine had these but had someone else install them for him. I'm just needing to find out how to install these headers whether it'd be easy enough to do it myself or if i'd be a lot better off taking it to a shop
Old Aug 31, 2005
Da1lyDr1ver's Avatar
i've never heard of your header brand. you shouldnt have to take off so many parts just to put on the header. is it just the header or does it have a downpipe also? if its a shorty header, you shoulnt need to take anything apart other than the exhaust piping. if it comes with a downpipe, then you might need to move some things apart. either way, you shouldnt need to touch the motor mounts...
Old Aug 31, 2005
htuner34's Avatar
It's just the header the single pipe that goes to the cat is maybe 3" to 3 1/2" long. Will the best way to get them in to run them up from below the car or drop them in and twist and turn.
Old Aug 31, 2005
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
Just drop it in from the hood. You shouldn't have any clearance problems. Just remember to let the car cool down before touching the stock headers and bring some WD-40 to loosen the bolts.
Old Aug 31, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
you should just be able to unbolt the stock header from the engine and the cat, and then bolt the new one back in the stock position locations.
Injen
Old Aug 31, 2005
gangrel138's Avatar
^^^ What he said.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
