How low should your gas pedal go down?
Old Aug 25, 2005
DMB's Avatar
DMB
DMB is an unknown quantity at this point
I was just wondering how low should your gas pedal go down when you press on it/drive. (2002 Honda Civic Coupe)
My gas pedal is kind of low (alittle lower than the brake)..... I have to press down alittle bit to go...... I was wondering if you allhave this situation/problem, or if it's normal.
How often do you get this checked/fixed?
I'm getting 4 new brake pads installed next month (preparing for the winter)
Old Aug 25, 2005
Zzyzx's Avatar
Autocross Junky
not sure what your asking here... but Yes the gas pedal sits lower then the brake...
Old Aug 25, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
And if you haven't messed with your throttle body cable, the gas pedal should have a little bit of "give" in it between when you start pressing on it and when the engine responds.
Old Aug 26, 2005
PANMAN's Avatar
PANMAN has a little shameless behaviour in the past
You Should Tighten Your Throttle Cable, It Will Give You A Better "sence" Of Throttle Responce. Make Sure It Is Tight Though Or You Will Be Going Through Traffic, And The Next Thing You Know, Your Gas Pedal Does Nothing
Old Aug 26, 2005
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
and that, my friend, would suck
WaryDriver
23
Jul 22, 2015 07:18 PM
carlinag13
Jun 18, 2015 09:49 AM
cukaracha
Jun 4, 2015 08:25 AM
Bradel26
May 30, 2015 10:24 AM
anddrrey
May 11, 2015 02:30 PM
