oil filter
oil filter
i been having problems removing my oil filter when it's time to change my oil it's getting so tight that i have to put a hole in the filter with a screw driver to remove the filter. Any idea's ? My SL65 rim, because a rim is all I can afford
if you're removing the filter who cares if it's mangled?
Have you tried the filter arench where you connect a ratchet to it, that's my favorit for the civic because you don't ned much room.
Originally Posted by 03CivicEX4Door
I tryed 2 different types of oil filter wrenches, neither worked. using channel locks work's great, but the filter get's mangled.
Yeah yeah I know, if the filter isn't tight it's going to either leak or fall off thus ruining my engine. Thus, people really overtighten them thinking it's the one bolt/gizmo that needs to be tight otherwise the car falls apart.
That's the number one reason for people think it's OK to really tighten the filter. If you're pounding a screwdriver through to take it off it's too damn tight.
Just follow the instructions that every manufacturer puts on the can - 3/4 a turn after the gasket makes contact.
^but you'd have to wait like an hour cause of the heat. thats if you run the car for awhile then start changing the motor oil that is, which is how its suppose to be done.
how much does walmart sell oil filter wrenches for? what kinds do they have?
too many ppl over tighten the oil filter i swear...just like flashlightboy said...only suppose to turn it 3/4 turn or one whole turn and no more. that's why there a gasket there to keep it seal with no leaks
mistermenphis22
Jul 13, 2015 04:43 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
