k20a3 swap....
k20a3 swap....
Hasport says using a k20a3 from a base rsx that the Intake manifold will not fit over the core support. They suggest using a SI manifold (same as a type s manifold). That means I need a TB and the si ECU too or kPRO. Has anyone swapped a base rsx k20a3 without changing the intake manifold?
this has been an atl01 production..
Originally Posted by atl01
Well hasport needs to do some more research, because i have had an base RSX A3 motor in my car for over a year now and it fit fine. The shop did have to cut a little of the core support but not much. The base RSX manifold(the balck plastic one) is a dual runner intake manifold like on the old GSR's The manifold on the Si is close to the one on the type S but the runners are a little shorter. But if your going the switch manifolds i would get K-pro for the base motor that way you can turn the dual runner function off. Hope this info helps with your swap,
Its a celebration bitches!
all u need is the manifold, the Si and rsx S have the same maifold. the base has the dual stage, the si and rsx S has only the single stage.
get the aluminum mani. you can hook everything up to that perfectly...
thats plastic manifold WILL NOT work in our engine bays
dam with suspension and slicks and on a good diet (weight) seeing that ep3's with full bolt-ons and falkens running mid 14's (still very hard but seen a few in person), u could break 13's but dont know. Not a bad setup though especially when u get it tuned. Cant wait for dyno #'s.
yeah all i have is the motor sitting at home right know. **** can change fast though. A guy just asked if i wanted to buy a k20a with everything except TB for $5000 CDN.
lucky13matt
Jun 16, 2004 05:39 PM
