k20a3 swap....
Old Aug 10, 2005
kornsined's Avatar
k20a3 swap....
Hasport says using a k20a3 from a base rsx that the Intake manifold will not fit over the core support. They suggest using a SI manifold (same as a type s manifold). That means I need a TB and the si ECU too or kPRO. Has anyone swapped a base rsx k20a3 without changing the intake manifold?
Old Aug 10, 2005
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
why don't you go with a k20a3 from an si.....wouldn't that help u its the same engine as base and NO THE SI MANIFOLD IS DUAL STAGE AND THE RSX TYPE -S IS SINGLE STAGE...IT IS NOT THE SAME
Old Aug 10, 2005
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
Well hasport needs to do some more research, because i have had an base RSX A3 motor in my car for over a year now and it fit fine. The shop did have to cut a little of the core support but not much. The base RSX manifold(the balck plastic one) is a dual runner intake manifold like on the old GSR's The manifold on the Si is close to the one on the type S but the runners are a little shorter. But if your going the switch manifolds i would get K-pro for the base motor that way you can turn the dual runner function off. Hope this info helps with your swap,
Old Aug 10, 2005
kornsined's Avatar
THANK you very much. I thought my whole swap was just fuked. To switch manifolds wouldn't have been worth it. i'd rather get a k2oa2 for all that extra $$.
Old Aug 10, 2005
ImportRacer2123's Avatar
K20 Member
I found my k20a2 intake manifold for 250 w/ TB and all sensors.
Old Aug 10, 2005
HondaLuver's Avatar
Its a celebration bitches!
all u need is the manifold, the Si and rsx S have the same maifold. the base has the dual stage, the si and rsx S has only the single stage.
get the aluminum mani. you can hook everything up to that perfectly...
thats plastic manifold WILL NOT work in our engine bays
Old Aug 11, 2005
atl01's Avatar
YES the plastic manifold that comes on the base will fit in our engine bays, I wish i could post pics of my swap but i dont have a dig camera, pm me and i will send whoever dont beleive me the pic via camera phone because my phone is full of them.
Old Aug 11, 2005
kornsined's Avatar
most people sasy you need the TB and ecu as well.
Old Aug 11, 2005
atl01's Avatar
All you need is the A3 motor, it will fit with the plastic intake manifold. TRUST ME.
Old Aug 11, 2005
HondaLuver's Avatar
^^ maby it will, but it doesn't look as nice...
Old Aug 11, 2005
atl01's Avatar
True, but anything looks better than a D17
Old Aug 23, 2005
kornsined's Avatar
hey i noticed hasport changed something....they don't list GSR axles as working for the swap anymore, any idea why?
Old Aug 23, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
cuz gsr axles don't work ;P
drivetofast has his Si/S intake mani for sale, since he now has a jrsc
Old Aug 24, 2005
kornsined's Avatar
weird I swear they listed them before. good thing i never bought any. si mani....don't think i'll be doing that.
Old Aug 24, 2005
allmotor's Avatar
nor cal 7thgens
dam props for sticking with k20a3. What r u gonna do mtr wise?
Old Aug 24, 2005
kornsined's Avatar
mtr?? you mean motor wise? probably CAI/header/kpro and possibly raz stage 1 cams
Old Aug 24, 2005
allmotor's Avatar
nor cal 7thgens
dam with suspension and slicks and on a good diet (weight) seeing that ep3's with full bolt-ons and falkens running mid 14's (still very hard but seen a few in person), u could break 13's but dont know. Not a bad setup though especially when u get it tuned. Cant wait for dyno #'s.
Old Aug 24, 2005
kornsined's Avatar
yeah all i have is the motor sitting at home right know. **** can change fast though. A guy just asked if i wanted to buy a k20a with everything except TB for $5000 CDN.
Old Aug 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
$4200 for a k20a swap, not a bad price.
Old Aug 25, 2005
kornsined's Avatar
yeah this could also be a scam too....
S800Racer
Aug 16, 2004 07:53 AM
lucky13matt
Jun 16, 2004 05:39 PM
S800Racer
May 11, 2004 11:40 AM
Sparco_typer
California
Apr 5, 2004 02:28 AM
Jodster
Engine Swaps
43
Jan 29, 2004 01:42 AM
