Pulley making weird sound
Old Aug 1, 2005
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
I just check with my friend today where the noise was coming from it was from the power steering bump. Should be the bearing inside is done.
I am using the aem tru power pulley kit, is it possible to just change the bearing? or I have to change the whole thing? Does anyone know how much that part would cost? and how long is job take, And anyone have a picture or a link for the bearing ?
Thanks
Old Aug 1, 2005
streetglower's Avatar
basically you would need to pull the pump and overhaul it to find out what is actually wrong. You can replace individual parts inside, so just go in and find out if it is the bearing.
Old Aug 1, 2005
es2k2's Avatar
Proud to be a civic owner
what kind of noise you have from the bearing?
Old Aug 2, 2005
jdm_bb's Avatar
ok thanks streetglower and the noise that it makes it's kind of like metal to metal
it's pretty loud when i rev the car
Old Aug 2, 2005
CraigW's Avatar
Have you checked the mounting bolts ?? I had noise after a repair once and the guy had forgotten to tighten the bolts on one of the pulleys, Yours may have worked loose.
Old Aug 2, 2005
jdm_bb's Avatar
mounting bolt? is there where that locks the power steering pulley?
Old Aug 2, 2005
CraigW's Avatar
I looked at mine and there is only 1 nut, Worth a check though.
mrohitredd
18
May 14, 2015 07:35 PM
dennis123
May 3, 2015 03:14 PM
SSMatey
Apr 13, 2015 06:09 PM
Ronin
Nov 17, 2001 09:46 PM
