just a simple yes or no answer will suffice...
Crayons taste like purple...
If i buy new springs and since they're obviously a different height then o.e.m. does that mean i have to buy adjustable shocks to or do they work with non-adjustables?
just don't rip me a new hole if this is a stupid question
Well, it depends on what you want to do. Are you just tring to imporove looks, or are you doing it for handling?
In short though, yes, most good quality non adjustable shocks will work fine.
Note that I say GOOD shocks, cheap shock will blow out very quickly. You get wht you pay for.
You dont need new struts/shocks. You can use the OEM ones. However, just remember that the OEM ones are weak and arent designed for a lowered, stiffer spring. Basically they cant handle the higher rate of oscillation(bouncing) and will most likely wear out pre-maturely.
do you care about ride comfort? if so, yes, struts are highly recommended.
dropping lowering springs on factory struts will ride nice for the first days, but it'd eventually wear and result in a super shitty ride quality.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
robjcivic
Mar 12, 2017 12:10 PM
Munzy
21
Oct 7, 2015 07:48 AM
Islesfan
Sep 29, 2015 03:42 AM
