just a simple yes or no answer will suffice...
Old Aug 1, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
Question just a simple yes or no answer will suffice...
If i buy new springs and since they're obviously a different height then o.e.m. does that mean i have to buy adjustable shocks to or do they work with non-adjustables?
just don't rip me a new hole if this is a stupid question
Old Aug 1, 2005
Jrfish007's Avatar
Well, it depends on what you want to do. Are you just tring to imporove looks, or are you doing it for handling?
In short though, yes, most good quality non adjustable shocks will work fine.
Note that I say GOOD shocks, cheap shock will blow out very quickly. You get wht you pay for.
Old Aug 1, 2005
blouisgod's Avatar
Life Begins > 6800rpms
nope
Old Aug 1, 2005
flotsamm's Avatar
You dont need new struts/shocks. You can use the OEM ones. However, just remember that the OEM ones are weak and arent designed for a lowered, stiffer spring. Basically they cant handle the higher rate of oscillation(bouncing) and will most likely wear out pre-maturely.
Old Aug 1, 2005
jttegx's Avatar
OMNES AD UNUM
do you care about ride comfort? if so, yes, struts are highly recommended.
dropping lowering springs on factory struts will ride nice for the first days, but it'd eventually wear and result in a super shitty ride quality.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
robjcivic
Mar 12, 2017 12:10 PM
Munzy
21
Oct 7, 2015 07:48 AM
Islesfan
Sep 29, 2015 03:42 AM
carid
Sep 28, 2015 10:13 AM
