Airbags- Pro And Cons?
Old Jul 25, 2005
glassJAwzr's Avatar
glassJAwzr is an unknown quantity at this point
Question Airbags- Pro And Cons?
Im seriously thinking of getting an airbag suspension installed on my sedan,but first i need the advice of peeps who already have bags.what are the pros and cons of the airbag system? and not to be nosy but what kind of systems are you running on your cars? is it true if i were to get cylinders that my car would wobble real bad if i go at a high rate of speed? cuz i still want to haul a litlle *** in my car. all advice will be greatly appreciated.thanks
Old Jul 25, 2005
glassJAwzr's Avatar
Im really not trying to get a cheap setup ,im going for the top of the line setup.the one with the least headaches and best quailty.
Old Jul 25, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
he is talking about airbags for the wheels/suspension
Old Jul 25, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
Old Jul 25, 2005
blackbullet's Avatar
The Legend
If you drive your car daily I wouldn't get them. Too many little things can go wrong. Pain in the a$$.
Old Jul 25, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
I second this.....
Old Jul 29, 2005
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
Originally Posted by nitroal1973
I second this.....
what little things?
Old Jul 29, 2005
bags won't fit new civic's right?? you have to have air struts.
Old Jul 29, 2005
kumanan's Avatar
what??? bags dont fit 7thgens?
Old Jul 30, 2005
HondaNation's Avatar
Got Bags?
HondaNation is on a distinguished road
i agree with blackbullet.....i got bags but i dont drive my car hardly at all.....i would go with AIM ind. they carry good bags for our vics....a lil high on price but its worth it....do you want direct bolt on? if so AIM is the way to go....a good kit will run you about 2200 direct bolt on
just wanted to share
Old Jul 30, 2005
dru106's Avatar
ThE CoRRupToR
Air bag suspension is definately for show purposes only. You dont see ppl wit airbag suspension go canyon running...........
Old Jul 31, 2005
kumanan's Avatar
so they dont got bags for our civics?? i gotta get struts? arent struts so much more expensive then bags
Old Aug 1, 2005
dru106's Avatar
ThE CoRRupToR
no, bags cost twice as much as full coilover damper but the dampers are much better in terms of performance. Bags are just for looks thats all......
Old Aug 1, 2005
Narfcake's Avatar
Narfcake is an unknown quantity at this point
Air bags are more than just looks, and a proper setup can yield better performance, as such is dynamic for the conditions. Such said, dialing in the right pressure/length at the right moment via an active or semi-active system isn't exactly trivial, and to do it right essentially means reengineering the suspension system.
If going with bags, use such to replace springs and supplement the struts, which one would want revalved to the characteristics of the bags (see comment above).
Unless you're willing to go through such lengths, don't consider it unless you're only after the looks.
-- Kane ... and yes, coilovers are a much more cost effective solution to performance. Why reinvent something which already works - the coil spring - right?
Old Aug 1, 2005
kumanan's Avatar
what websites sell air ride kits other then aim.. i checked everywhere...
beanhead
Sep 24, 2015 12:04 PM
krazykoncepts
Sep 8, 2015 09:02 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
