3 inch piping...
Old Jul 30, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
3 inch piping...
Hey guys, who here is running 3 inch piping w/ boost, did you feel a big difference before the 3 inch? Any pics? Thanks!
Old Jul 30, 2005
turboengnr's Avatar
DONT PANIC
with a 3" straight through exhaust, i was able to gain about 15 whp over a 2.5" exhaust with a resonator and muffler.
Old Jul 30, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
how much hp does a cat take away on stock vs turbo???
Old Jul 30, 2005
turboengnr's Avatar
DONT PANIC
depends. You could be losing 2 hp or you could be losing 50.
on my 85 vette i gained almost 35 whp when i cut the cat off. But that was because they put a 2" cat on my dual 2.5" exhaust (bastards!)
Old Jul 30, 2005
jackburton's Avatar
what about on d17
non-built engine-stock vs turbo
damn 35 whp with no cat-------------SWEET!!!
vettes aslo SWEEETTTTTTT!!!!!!!!!
Old Jul 30, 2005
turboengnr's Avatar
DONT PANIC
you can gain a bit. I have an LX, so i never had a cat to worry about (took it off in order to install the turbo)
Old Jul 30, 2005
Alex1's Avatar
Hey Mike, what about the gains of a 2.5" to 3" downpipe?
Old Jul 30, 2005
turboengnr's Avatar
DONT PANIC
it depends. If you are running relatively low boost, you wont see much of an improvement.
Im going from a 3" to a 4" downpipe. i will probably gain a few hp. maybe 10
Old Jul 30, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
It also depends on what turbo you are running. If you have a t25 you arent gunna wanna put 4" exhaust and downpipes on your car. turboengnr has a sick setup and can benefit from it. I have a t3/t04e and the outlet on the turbo is only 2.5 inches and I am running mandrel bent 2.5 DP and piping with no cat all the way back. Maybe I could go bigger than 2.5 but at 8-10 pounds I dont think thats where I need to focus at the moment. Its all relative to what you are doing. My friend put a 3" DP and exhaust on his turbo hatch and gained almost 20 whp. Also if you take the cat off while you are N/A usually you can expect to lose some mid and low range power in favor off the top end, even more if you have no resonator or muffler.
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
Islesfan
Sep 29, 2015 03:42 AM
