3 inch piping...
DONT PANIC
depends. You could be losing 2 hp or you could be losing 50.
on my 85 vette i gained almost 35 whp when i cut the cat off. But that was because they put a 2" cat on my dual 2.5" exhaust (bastards!)
It also depends on what turbo you are running. If you have a t25 you arent gunna wanna put 4" exhaust and downpipes on your car. turboengnr has a sick setup and can benefit from it. I have a t3/t04e and the outlet on the turbo is only 2.5 inches and I am running mandrel bent 2.5 DP and piping with no cat all the way back. Maybe I could go bigger than 2.5 but at 8-10 pounds I dont think thats where I need to focus at the moment. Its all relative to what you are doing. My friend put a 3" DP and exhaust on his turbo hatch and gained almost 20 whp. Also if you take the cat off while you are N/A usually you can expect to lose some mid and low range power in favor off the top end, even more if you have no resonator or muffler.
Islesfan
Sep 29, 2015 03:42 AM
