Problem with Rear Sway
I just installed my Progress Group Rear Sway bar w/tie bar and the bar is touching the exhaust cannister.(not the piping the actual canister). I also hear a wierd kinda creaking/banging noise. Not sure if its from it hitting the exhaust or because they just do that. But hitting the exhaust is definately a problem.
I zip tied(ghetto?) part of an injen hose clamp between the exhaust and the sway bar so they don't tear each other apart. Tried banging exhaust in a lil to give the sway some clearence to move around(didn't work).
Kinda stuck.
Installing my front sway later tonight as with some struts for a 180sx.
I called progress and they seemed to not understand why it was touching the exhaust. I am going to try and move the brackets all the way down and see if it helps at all.
Will post pics later tonight when I try and fix it.
HELP
Kinda stuck.
HELP
Autocross Junky
What endlinks are you using? stock? adjustible? if they are adjustible you can lengthin then a little and gain a bit of clearance.
Tried installing Progress Front Sway and can't get the driver side endlink bolt off
any suggestions. When I turn the nut the whole bolt turns
and its almost impossible to keep the metal bracket behind it from moving.
Originally Posted by Zzyzx
THeres an alan key hole on the end of the bolt... use it to stop the assembly from turning. :P
Oh yeah another problem though. It seems that the bolt for the strut bar mount(the upper right side) The threads were screwed up, so when we put it in it messed up the whole.
What can I do, Rethread the whole for a bigger diameter bolt?
Originally Posted by mkingk2
Thanks, I'm surprised sitting under there for 2 hours it didn't dawn upon me to check that lol. The DIY says hexagonal thingie ahaha.
Pudnite
May 9, 2015 07:51 PM
oneheadlight
Apr 29, 2015 11:30 PM
ej8
Apr 13, 2015 06:36 PM
