Problem with Rear Sway
Old Jul 14, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
I just installed my Progress Group Rear Sway bar w/tie bar and the bar is touching the exhaust cannister.(not the piping the actual canister). I also hear a wierd kinda creaking/banging noise. Not sure if its from it hitting the exhaust or because they just do that. But hitting the exhaust is definately a problem.
I zip tied(ghetto?) part of an injen hose clamp between the exhaust and the sway bar so they don't tear each other apart. Tried banging exhaust in a lil to give the sway some clearence to move around(didn't work).
Kinda stuck.
Installing my front sway later tonight as with some struts for a 180sx.
I called progress and they seemed to not understand why it was touching the exhaust. I am going to try and move the brackets all the way down and see if it helps at all.
Will post pics later tonight when I try and fix it.
HELP
Old Jul 14, 2005
Zzyzx's Avatar
Autocross Junky
What endlinks are you using? stock? adjustible? if they are adjustible you can lengthin then a little and gain a bit of clearance.
Old Jul 14, 2005
mkingk2's Avatar
Stock Endlinks
Old Jul 15, 2005
mkingk2's Avatar
Tried installing Progress Front Sway and can't get the driver side endlink bolt off
any suggestions. When I turn the nut the whole bolt turns
and its almost impossible to keep the metal bracket behind it from moving.
Old Jul 15, 2005
Zzyzx's Avatar
Autocross Junky
THeres an alan key hole on the end of the bolt... use it to stop the assembly from turning. :P
Old Jul 15, 2005
mkingk2's Avatar
Thanks, I'm surprised sitting under there for 2 hours it didn't dawn upon me to check that lol. The DIY says hexagonal thingie ahaha.
Oh yeah another problem though. It seems that the bolt for the strut bar mount(the upper right side) The threads were screwed up, so when we put it in it messed up the whole.
What can I do, Rethread the whole for a bigger diameter bolt?
Old Jul 15, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Which threads did you screw up? You can't rethread the strut hats if you ****ed those threads up, you need a new strut hat. Have fun with that one.
Pudnite
May 9, 2015 07:51 PM
shindrome
Exterior
May 5, 2015 02:50 PM
oneheadlight
Apr 29, 2015 11:30 PM
ej8
Apr 13, 2015 06:36 PM
Firefly
Nov 28, 2001 06:13 PM
