`04-`05 Fog Light Removal
Old Jul 1, 2005
mini-nsx's Avatar
mini-nsx is an unknown quantity at this point
All I need to do is change the F'ing bulb...
Do I have to take the bumper off or what?
Our `04 EX-SE came with fog's allready installed. So I didnt do it, but there seems to be no way to get in behind the thing to replace the bulb...
HELP! I find it hard to believe Honda would make you have to take off the front bumper to change the fog light bulb. But I dont see any other way to get behind it. Does the thing clip in and clip out? I dont wanna pull to hard and break something plastic...
BTW the search button sucks for things like this. the words removal and bulb bring up all kinds of topics...
Thanks in advance!
Old Jul 2, 2005
ImPulse's Avatar
arent there 2 screws holding each fog light to the inner bumper?
unscrew them and pop it out, then take the bulb out
Old Jul 2, 2005
mini-nsx's Avatar
And where would these two screws be located? The fog's on the `04-`05 are different than the `01-`03. My RSX-S's were held in with two screws from the side that were accessible from the front bumper, but no dice on this one...
Old Jul 2, 2005
ImPulse's Avatar
take off the front bumper then... not that hard to do
Old Jul 3, 2005
mini-nsx's Avatar
I never said it was hard, I just cant believe Honda made it where you have to take the thing off...
I wanted to double check before I pulled the thing off only to find out I didnt have too...
Thanks for your help...
Old Jul 3, 2005
wait lemme check something. I know 01-03 had the screws, but...
Old Jul 3, 2005
there is one bolt directly under the foglight, just look under the bumper. Then they pull out.
Old Jul 4, 2005
mini-nsx's Avatar
^ ^ Thanks for the help, I'm at work right now. I walked out and felt under, but only felt two clips, a screw and one bolt, but it was pretty far back...
I plan on changing the oil tonight, so I'll have her up on jack stands and be under her then. I guess I'll pull off the bumper if I dont find what you talking about...
Old Jul 4, 2005
you can goto www.handaaccessories.com and download the .pdf instructions and check near the last page. It tells you how to change bulbs.
Old Jul 4, 2005
mini-nsx's Avatar
100 rep points to you bro...
Thanks a lot, you have to stick a 10mm on an extension up in a hole in the bumper under the fog light...
More frusteration though, the dealership and a web-site on the internet (I dont remember which one) showed the bulb to be a Sylvania H11. We looked everywhere for that bulb, but had no luck...
So I spent $15.00 on one bulb from autobarn.com...
Guess what? Its an H8 bulb and the H11 wont fit, even if it would fit, I'm not sure I'd want it because I'm not sure they would match right...
Sucks to be in love with cars and have my luck sometimes...
Thanks though, I guess I'll just leave it out and drop by O'Reilly's on the way home...
Old Jul 4, 2005
i think these are the correct stock bulbs. They're kinda pricey but says they last 2x longer than regular bulb.
http://www.ambulbs.com/products/description.php/II=37
Old Jul 10, 2005
roadstr468's Avatar
roadstr468 is an unknown quantity at this point
Just for clarification, the oem fog light switch location is directly in front of the shifter, correct? Or more specifically, is there a factory wiring harness connection that is capped on an EX for models not equipped with fogs, or is it a completely new wiring harness if your car is not equipped w/o fogs?
Thanks in advance
Old Jul 10, 2005
there is no existing fog light hardware. Everything comes with the kit and has to be wired, making it a big job.
Old Jul 10, 2005
roadstr468's Avatar
Yeah i just read the install. sounds "fun." anyone accomplish it yet that you know of in case i have any questions during the install? I'm still deciding if i really want them though.
Old Jul 10, 2005
well they're cool i guess. doesn't really help with visibility cause they don't really light up the part of the road you can see sitting in the seat. I had dealer do mine. I guess get them more for looks.
Old Jul 10, 2005
roadstr468's Avatar
Thanks for the help anyway man.
Old Jul 11, 2005
mini-nsx's Avatar
Yeah, I wish they would make them like my Titan, I think it took me 15 minutes to install the fog's...
The truck was pre-wired for them, each held in by a bolt, then plug them in. It was intimidating to change out the turn signal / headlight controll staulk on the sterring colum at first. But pull the cover off and it snapped out and the new one with the fog switch snapped in...
Old Jul 12, 2005
roadstr468's Avatar
I was looking at the upper and lower Column fascia today, and i looks like there is no good way to remove them without forcing a flat head through the seam and prying them apart. But doing that will leave indentations in the vinyl fascias. How did you do it without deforming the fascias?
Old Jul 12, 2005
dirtySAMURAI's Avatar
I log in from time to time
what are you talking about?
Old Jul 12, 2005
lol i think he means the bumper? you gotta cut holes out for the fogs.
Old Jul 12, 2005
roadstr468's Avatar
the upper and lower "fascia/housing" for the steering column right behind the steering wheel. The two piece are snapped together so freakin tight. i don't want to scratch them when i rip them apart. Thats why i wanted to know if there was a way to release the clips holding the bottom housing to the top housing in a manner that would not damage anything. if i pull any harder on them, i think i am going to rip the bottom half; its really flimsy.
Old Jul 13, 2005
why are you trying to take apart the steering column? installing fog lights has nothing to do with it...
Old Jul 13, 2005
roadstr468's Avatar
I'm not an EE, but i after reading the installation instructions, http://www.handaaccessories.com/civext01.html, (page 13), i assume the car would spit out a fault if you did not connect the switch harness to the Lighting control on the steering column. If the fog lights still worked and did not require the headlights to be on by leaving this connection alone, i would prefer it. Anyway that is why i am digging through the steering column
Old Jul 13, 2005
http://www.7thgencivic.com/forums/sh...d.php?t=204356
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
