car cuts off and on radomly
Old Jun 7, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Question car cuts off and on radomly
I dont know why but for some reason my car "cuts off and back on" when im driving, or at idle. I havent noticed it happening on the highway, just at idle or slow cruising. Has anyone had this issue?
Old Jun 7, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Have you tried reseting the computer?
Old Jun 7, 2005
SODJAZERO's Avatar
ive tryed that
Old Jun 7, 2005
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
my car does the same ****...like if im at a red light it just bogs until the point my is going to turn off...and sometimes when i'm just slow cruising my car turn off completely...
Old Jun 7, 2005
Tomola's Avatar
Tomola is an unknown quantity at this point
thats fu(ked!
Old Jun 8, 2005
check your o2 sensors, could be sometihng to do with that or the Map or the umm cant remember the other one. But its in the throtle body,
Old Jun 8, 2005
Just thought of something elses.. What does your car normally idle at?
Old Jun 8, 2005
SODJAZERO's Avatar
it normaly idles at like 760 something, im not sure if its at a idle problem because it almost never happens over 3k rpm... this **** sux, its like the d@m car hickups or something... . Are there any honda techs on here?
Old Jun 8, 2005
got any mods on your car?
Old Jun 8, 2005
SODJAZERO's Avatar
turbo, safc, sf-fmu, but the engine is all stock. .. .
Old Jun 8, 2005
2K1Civic17"Gabe's Avatar
hehe, not stock anymore with a turbo, lol.
Do you have something for the MAP? like a missing link, black box, anything? You need to make sure the MAP isnt seeing boost. Do you have a CEL? If so get it checked out, and if it says something like, "High Voltage __________" its your MAP seeing boost. Dont drive without the missing link.
Are all your o2's, and sensors plugged in?? Make sure all your electrical connections are solid, especially ones with the MAP or ECU. I hope they are soldered as well. If not, Solder them bitches NOW!. hehe
You can also check your TPS, but that has to do with idle, so that shouldnt be it. If it only happens under boost, and boost causes a CEL, its more than likely your ECU seeing boost. The CEL would probably go off on idle, but when you start driving and hitting some boost, it would throw the code. Make sure ir AIT (air intake temp) sensor is in as well. The one near the TB, that goes into the charge piping.
Old Jun 8, 2005
mexinaction's Avatar
mine does the same thing, but i think it might be due to the subs, amp, 3 screens in-dash and dvd player.
its probably the alternator.
Old Jun 8, 2005
thats exzactly what i was thinking. damb it you beet me to it
Old Jun 8, 2005
SODJAZERO's Avatar
Well for one the car doesnt see boost at idle. Which is when it mostly happens. The iat sensor is not in. This problem just started. All o2 sensors are plugged. How do you check a tps? No cel.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
2k1Vtecivic
Nov 3, 2001 10:37 AM
