Amount of oil
Old Jun 7, 2005
DrOpPeD2k2CiViC's Avatar
DrOpPeD2k2CiViC is an unknown quantity at this point
Amount of oil
This is one hell of a noooobb question and i feel like a dumbass asking it but i lost my owners manual somewhere. How much oil do our cars take with a complete oil and filter change in a 02 civic ex 5 speed.. i think its around 4.6 but i cant remember correctly
thanks in advance
Old Jun 7, 2005
HondaLuver's Avatar
Its a celebration bitches!
lol... search...
Old Jun 7, 2005
Rennen's Avatar
New Mod on the Block
i put 3 1/2 - 4 quarts in my car.
Old Jun 7, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
4.6 quart. Too much, this isn't a V6.
I just put 4 quart.
Old Jun 7, 2005
04civicdx's Avatar
04civicdx is an unknown quantity at this point
3.5 Qt
Old Jun 7, 2005
AzNTiG3R's Avatar
Member
AzNTiG3R is an unknown quantity at this point
According to the manual, 3.6 for EX and 3.4 for LX and DX. Hope this helps.
Old Jun 7, 2005
2K1Civic17"Gabe's Avatar
I put about 4.5. But I am turbod, and have extra lines and parts for oil to flow through. Stock is between 3.5-4.
4 quarts always worked good before i was turbod. it went right to the twist in the dipstick where it should be.
Old Jun 7, 2005
Thanks everyone except for the smartasses we have here
Old Jun 7, 2005
jttegx's Avatar
OMNES AD UNUM
03 ex auto.
manual says: 3.7 qt and thats if its FULLY drained meaning to the point where the motor is flushed cleaned.
when i change my oil and oil filter, its about 3.5 or 3.6 in most cases.
remember, its always better to fill less cause if you overfill, you would have to remove the oil filter to take out the overfill amounts. so fill around 3.3 quarts and keep checking the dipstick. and the engine would suffer if you just turn it on for awhile while theres only 3.x quarts in there. just a tip
Old Jun 7, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Why would you have to take off the filter? Just take out the drain plug. And I usually put 4 in. .3 qt is not going to affect it that much for me to justify having a small amount in a bottle sitting on a shelf.
Old Jun 7, 2005
blouisgod's Avatar
Life Begins > 6800rpms
yah 3.7 when fully emptied.
Old Jun 9, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
can someone tell me what it says for the 5 speed tranny ? how much quarts?
Old Jun 9, 2005
Storm897's Avatar
Storm897 is an unknown quantity at this point
DIY Manual Transmission Fluid change. I think its about 1.6 or 1.7 quarts.
Old Jun 11, 2005
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
I usually fill up with about 3 1/2... Start the engine, let the filter fill up and then shut the car off, check the level again, put whatever it needs to reach the full mark.
Old Jun 11, 2005
mclean987's Avatar
no its alot mroe they say to fill it until it overflows it has to be atleast 2.3 quarts-2.5qts.
Old Jun 11, 2005
HondaLuver's Avatar
my engine takes like 4.5, i think
Old Jun 17, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
no if you go to a honda dealership and you ask for more than 2 quarts of manual tranny fluid for a 7th gen they will simply ask if you plan on spilling a qt.
Old Jun 18, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
3.7 quarts of 5-20 oil. 1.6 of HONDA MTF. nothin less. maybe 1 quart extra just in case something happends.
Old Jun 19, 2005
mclean987's Avatar
1.6 thats all in the tranny ? did that come from the manual? i put like 2.5-3
Old Jun 19, 2005
MajinB's Avatar
yeah thats from the manual. don't drown your tranny. btw its for a dtick tranny not auto. i have no clue about autos. does your car still run after putting in 2.5/3? cause if its a stick it shoudln't run. if its an auto it shouldn't run either.
Old Jun 20, 2005
Storm897's Avatar
Wrong. I did mine last year and it was less then 2 qts. I just helped my neighbor do his 2 weeks ago and it was slightly less then 2 qts. He bought 2 qts of Honda MTF and some was left over. It even overflowed slightly.
I'll checked the Honda Service Manual once I get home, but I am 100% sure its somewhere around 1.7 quarts.
Old Jun 20, 2005
orso's Avatar
orso is an unknown quantity at this point
well i put 3.7 qts. drain put in 3 1/2 then slowly our the rest put the cap on crank car let run for a minute then check for leaks and dipstick for right amount of oil. it should be right at the top hole on the dipstick. 3.7 if you are changing the oil filter at the same time. maybe like 3.5 without oil filter change, but i change the filter every time.
Old Jun 20, 2005
MajinB's Avatar
i put clean oil in the new filter. like 1/4 full of new oil in the filter that way the motor doesn't start up dry. well not all dry but you guys know what i mean. anyway it helps.
SimpleUser
Apr 24, 2021 02:54 AM
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
cukaracha
Aug 10, 2015 08:01 AM
honda.lioness
Aug 6, 2015 11:58 AM
suburbanite
Jul 17, 2015 03:05 PM
