taking out airbag
Old May 29, 2005
CenZ's Avatar
PWIT
taking out airbag
hey, im trying to take the airbag out of my wheel, cause somehow i dropped a quarter behind it, and now my horn goes off randomly, and im afraid my airbag is going to go off cause of it. so how exactly do i get it off to get this stupid quarter out. i see some torx screws, so i just take those out and it comes right out? also, what size? thanks in advance,
Old May 29, 2005
streetglower's Avatar
first off you need to stop what you are doing before you kill yourself. Did you remove the negative cable from the battery and wait about 10 minutes? Did you remove the SRS connecter? If you did neither of those, and are still trying to remove the cover on the steering wheel, you are going to be seriously injured when that airbag explodes in your face. People have been killed (decapitated) by the airbags.
You need to first remove the negative battery cable and wait 10 minutes. The SRS has a backup battery and waiting the 10 minutes will disable it.
Old May 29, 2005
CenZ's Avatar
PWIT
i havent touched anything yet, im to scared too. lol. you got any idea how to take it off once i disconnect the battery?
Old May 29, 2005
tacheon's Avatar
tacheon is on a distinguished road
Removing the negative cable and waiting 3 minutes before working on it is sufficient according to Honda service procedures. You remove the T30 torx bolts and the airbag/horn unit comes straight out. You should be able to shake out the quarter once that is done. Replace the torx bolts and tighten to 7.2 ft*lbs.
Old May 29, 2005
well I said 10 minutes just to be on the safe side. I have heard from people that they waited according to the manaul and it wasnt long enough.
Old May 29, 2005
tacheon's Avatar
There is no backup battery hooked to the Honda airbag/srs system. Three minutes is more than enough. Honda and Acura vehicles only store a charge in a capacitor for 15 seconds after power is lost. Three minutes gives you a huge safety margin. That being said, there are other ways of detonating an airbag after the power has been disconnected. If you backprobe with the incorrect tool, or disconnect the airbag harness and subsequently cause a static discharge, you will detonate the airbag and injure or kill yourself.
Old May 29, 2005
CenZ's Avatar
PWIT
oh man do i feel safe doing this lol. how do i know what 7.2 lbs of torque?
Old May 30, 2005
tacheon's Avatar
To be absoultely meticulous, use a torque wrench. BTW, it's 7.2 ft*lbs. Units are important =) You can do it by feel by tightening it to approximately the same feel as before, but there is no way of knowing if you did it properly. The bolt threading is relatively fine so there is a risk of stripping it if you overtighten. If you undertighten, I'm purely speculating that it probably won't hurt anything. However, engineers specify torque values for a reason.
Old May 30, 2005
CenZ's Avatar
PWIT
yeah i figured that. alright, imma attempt this today...
Old May 30, 2005
CenZ's Avatar
PWIT
im not an idiot, so i do know its ft*lbs, and i do know i should use a torque wrench i was wondering if there was another way of knowing with out me buying another tool. it cool though, i will buy another tool. would rather do it right.
Old May 30, 2005
75shot's Avatar
I <3 my Evo
75shot should not be trusted
ok i dont know about you, but this definitely seems like a dealership problem to me.
but if you really want to do this stupid diy: when the airbag goes off, it's gonna feel like mike tyson went a round with your face, and you'll have a quarter in your eye to boot.
Old May 30, 2005
CenZ's Avatar
PWIT
hey, found a little compartment the quarter came right out lol. new problem, well before i found this little compartment i disconnected my battery to do this and then i plugged it back in. well now my battery light come on and off. not sure why? any clue?
voblak2
20
May 4, 2023 02:08 PM
mattdoc
Mar 14, 2017 12:10 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
RIPSAW
Jun 9, 2015 08:33 PM
jimmyfloyd
May 20, 2015 07:06 PM
