My passengers side strut gave out (REAR)
Old May 28, 2005
PICHY's Avatar
ALGARETE
i have the koni struts and comming from the new england dragway on rt95 south there was construction on the road...bad bump with no signs that said BUMP plus it was dark as hell.... the car fell from the new pevement to the scraped pavement soooo ****ing hard i thought my car broke i half.. evryone spleeping in the car woke up like if i crashed andd ****... but here i knew this was gon happen sooner or later i saw this comming last year when my interior was getting done.. we redid the suspencion and i noticed the small ring on the koni strut was damaged... i hit it with a hammer and straightened out...it was all good untill i put in the box for music in the back.. that **** weighs a ton....but we will c what happens tomorrow ill try to fix it if not turn the coilover all the way up.....thankfully nothing else is broken.....YET
YES KONI SUCKS
ID:	54752   Click image for larger version
ID:	54753   Click image for larger version
Old May 28, 2005
goodtimes's Avatar
dam that sucks dude hope everthing works out ok..
Old May 28, 2005
Hayz's Avatar
man that does suck good that nothing else happened tho... hope it works out for ya!
Old May 28, 2005
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
arent there bump stops that prevent the shock from bottoming out?? lowered+kit+subs/amp+car full of people = baaaad news
let someone else drive next time!
Old May 29, 2005
PICHY's Avatar
ALGARETE
edit
got it
http://www.7thgencivic.com/forums/sh...=193245&page=2
Old May 29, 2005
PICHY's Avatar
ALGARETE
where is this adapter??? what does it look like?? i cant find it
Old May 29, 2005
flotsamm's Avatar
So it still failed with the newer lower perch? Whne I first installed my Koni's in the rear, I put some clamps on the shock in case the c-clip failed. It looks like ***, but I dont care. As long as I'm able to limp it home I'll be happy.
Lemme know if you want a pic of my clamps setup.
Old May 29, 2005
PICHY's Avatar
ALGARETE
no no no i got the old ones when the konis first came out..i have them for 4 years now...
Old May 29, 2005
wonderz's Avatar
wonderz is on a distinguished road
haha, another Koni sucks thread 'cause they didn't put in the adapter for their gc.
koni has life-time warranty, try to ask them to see if they can give u a replacement shock 'cause you got an early verison and didn't know about the adapter.
Old May 29, 2005
PICHY's Avatar
ALGARETE
where and what is the "ADAPTER" can someone tell me
is it a coilover adapter??????
Old May 29, 2005
wonderz's Avatar
ground control makes adapter for different types of shocks. basically you should know what shocks u want to use before u buy the coils.
http://www.ground-control-store.com/...p/II=520/CA=55
they don't sell just the adapter on their website, but u can call them up and ask to buy it from them.
added:
something like this...
Old May 29, 2005
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
added:
So with the adpater, you don't have to install the silver perch(that came with the rear konis) ?
Old May 29, 2005
PICHY's Avatar
ALGARETE
/yeah i want to know that alsoo... but in anycase
my car is away for the year im gon get either the teins or the hayame full coilovers... thx guyz i aprecitae your help
Old May 29, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
man you should bag it lol, it kinda looks bagged already, that sucks about it blowing
Old May 30, 2005
GaryC17's Avatar
By the way, how does the car ride/handle with the GCs + Konis ?
Old May 31, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Yes, GC has 2 kits, one for Konis that has a spacer with a recess in it for the snap ring. (and thats my hand in the picture) When the the sleeve lands on the snap ring, it compresses it like a compression ring in your engine and basically prevents if from popping out of that groove. If you've got early konis, they made the groove deeper, if you've got GCs for non-Konis, call and get Koni rear sleeves. Either way, use the respective warranties and it should be taken care of. Its rare for the snap ring itself to fail (break), but it does sometimes happen.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
pratik05
May 15, 2015 01:54 PM
civicns
May 8, 2015 09:49 PM
