Does anyone's car do this?
Old Jan 22, 2002
civicman10's Avatar
civicman10 is an unknown quantity at this point
When my car is off or just idling in neutral, i can easily put the shifter into a gear without holding down the clutch. Is that normal for our cars? If not i'm gonna go take it into HOnda to have them check it out.
Old Jan 22, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
i know you can do it with the car off. how did you find out it does this? it's an odd thing to try
Old Jan 22, 2002
civicman10's Avatar
<< i know you can do it with the car off. how did you find out it does this? it's an odd thing to try >>
Heh, well my friend was sitting in the passenger seat while the car was off and was playing with the shifter (he doesn't know much about manual cars). Once i saw him shifting with no problems i got a little confused.
Old Jan 22, 2002
newkid's Avatar
newkid is an unknown quantity at this point
u can't shift into gear without stepping on the clutch...when the car is ON
maybe ur friend was just going left to right...but not engaging a gear
dunnnnno have it checked
Old Jan 23, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
This is what I know from experience...
When I first got my car, I didn't know sh't about using a 5-speed. I tried moving the car to a gear WITHOUT pushing down the clutch (after starting it) and I got the most annoying sound a new car could make. It doesn't sound... right. If the engine is on, and you put it to a gear, isn't the car gonna try to move? (Let alone stall.) I don't get it. I don't have my car with me now to really confirm it. Just... go to the dealer and show the service department (unless someone here can make some sense of it.)
Old Jan 23, 2002
DoubleOSuk's Avatar
DoubleOSuk is an unknown quantity at this point
&lt;&lt;I tried moving the car to a gear WITHOUT pushing down the clutch (after starting it) and I got the most annoying sound a new car could make. It doesn't sound... right&gt;&gt;
Ahh, memories. I remember the first day I crunched a gear. The summer of '94 [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Jan 23, 2002
anibal's Avatar
anibal is an unknown quantity at this point
If the engine is off, sometimes you can shift through gears without depressing the clutch if the gears are properly aligned as easy as if you were shifting normally, if they aren't you'll notice they can't get into place, so don't force it into gear. If the engine is running, and do it without depressing the clutch, you'll grind the gears and the engine may stall.
Old Jan 23, 2002
ILLWILL's Avatar
ILLWILL is an unknown quantity at this point
i disagree with ya cuz i can do it wit the car on while im driving its and old trick all u got to do is catch the gear change want the revs are going down its difficult to do but one u got it it works for emergencies {like ur clutch messing up or not grabbing}
but wat i do agree is that i daubt you can switch will the car is on idle
so he should get it checked
as far as the car being off
that is natural all standards do it the trans is not spinnin so the clutch is not going to fight it and it would go rite in
if anybody has a question im me
Old Jan 24, 2002
89HondaLxi's Avatar
89HondaLxi is an unknown quantity at this point
okay when the car is OFF you can shift into any gear it doesnt matter.....but when its on you shouldnt be able to shift into a gear
Old Jan 24, 2002
SneakerPimp's Avatar
SneakerPimp is an unknown quantity at this point
I'm not sure if mine does that. I would be too scared to try it.
Old Jan 24, 2002
89HondaLxi's Avatar
with the car off you can shift all you want it doesnt matter if the clutch is in or out, the reason is there is nothing moving in the trani other then the shift forks....the gears dont move with the car off so it wont hurt anything!
Old Jan 26, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
<< with the car off you can shift all you want it doesnt matter if the clutch is in or out, the reason is there is nothing moving in the trani other then the shift forks....the gears dont move with the car off so it wont hurt anything! >>
thats good to know, my friend was just doing that in my car today while it was off and i was hoping it wouldnt hurt anything
Old Jan 27, 2002
Hwoody77's Avatar
Hwoody77 can only hope to improve
It is possible to shift through all your gears and not use the clutch without hurting the car. You just have to know your car's dynamics and the like...VERY hard to do. And some people when they race don't use the clutch at all...
Old Jan 27, 2002
Becky's Avatar
Becky is an unknown quantity at this point
i have shifted without using the clutch before.....i learned that trick a long time ago. you cant force it in you just have to push slightly up until it grabs...at least thats how i got it to work. and if your car is off yes you can shift between gears. if you go to the dealer they are gonna laugh at you and take your money for "looking" at it
Old Jan 27, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
I can shift w/out clutch only when the car is off (thank God).
Old Jan 28, 2002
CarbonFiberSi's Avatar
CarbonFiberSi is an unknown quantity at this point
When the car is off you can put it into gear all you want. Its not the best thing to do so don't do it too much but
I'm sure its not going to do any damage.
Old Jan 30, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
if ur car is runnig and it does that take it to the dealer it was happening to me and then my shifter cable broke
but defintaly take it in
Old Feb 4, 2002
CityGuySam's Avatar
CityGuySam is an unknown quantity at this point
im still trying to figure out how your car can be started and you fondling through the gears
Old Feb 6, 2002
Todd1's Avatar
Todd1 is an unknown quantity at this point
weird!!!!
Old Feb 6, 2002
Lightning's Avatar
Lightning is an unknown quantity at this point
Can with car off, not with it on
Old Feb 6, 2002
BIG's Avatar
BIG
I'd check it out bro, my car has never done that. Goodluck!
Lates
Old Feb 6, 2002
CityGuySam's Avatar
[IMG]i/expressions/face-icon-small-puke.gif[/IMG][IMG]i/expressions/face-icon-small-puke.gif[/IMG][IMG]i/expressions/face-icon-small-puke.gif[/IMG][IMG]i/expressions/face-icon-small-puke.gif[/IMG]
Old Feb 7, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
It sounds like the clutch is adjusted wrong, only problem with that is we don't have a cable clutch. Something may be binding, take it is asap.
Shifting without the clutch is speed shifting(engine running). It is all a matter of getting the synchros to match up at certain RPM's. Motorcycles and F1 cars have such close gear ratios that they don't need the use of a clutch after 1st. I wouldn't recommend doing this too often, for the result may be a few broken teeth on your gears.
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
