What size tweerers fit in the sail panels?
Old Apr 26, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
Do 1" tweeters fit in the stock EX/LX sail panels?
Thanks!
Old Apr 26, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Do you own a dremel tool? They may need modification depending on depth, etc...
Old Apr 26, 2005
Hurts2bStock's Avatar
Shinier than yours, meatbag
lol.....I hope dremel sends you royalty checks once and a while.....jk
Old Apr 26, 2005
BassKadett's Avatar
Yes, I do own a Dremel. Probably the best thing I own....other than a DVD burner.
Anyway....are you talking about the sails with the factory tweeter pods? I checked my "smooth" ones and it looks near impossible to dremel out a hole to mount the tweeters. Not enough clearance back there with the wires for the mirror.
Old Apr 26, 2005
I didn't look at your profile. I managed to get a set of EX coupe sails to work in a sedan. Another idea would be to take the stock sail panels from your sedan and mount them via a surface mount cup. From there, glass it to make it look like the EX flush mount. Just a few ideas I had.
Old Apr 26, 2005
BassKadett's Avatar
I have a coupe
I could do that, but if I can get the EX sails for $7 each at my dealer and the install will go very smooth, I'd rather go that route. And I've never glassed anything before.
Old Apr 26, 2005
In that case, the EX sails will work perfectly. You may have to cut and trim them a little to accomodate the flush mount cup, but they're not a problem. That's the method I'd recommend and use every time.
Old Apr 26, 2005
BassKadett's Avatar
Thank you. So a 1 incher is the correct size?
Old Apr 27, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
diamond audio tweeters fit...i'm running diamond audio m3 components right now, and using EX sail panel
the m3's came with 2 sets of adaptors for the tweeters, one set was too long to fit, but the other set was perfect fit.
Old Apr 27, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
It's tweeter specific. Even tweeters of the same size will have mount cups, different shapes, no screws, 2 screws, tabs, etc, etc. Yes it's possible to fit 1" tweeters, but some are easier than others. I'm struggling to remember what speaker it is, but I dealt w/ one last year that was a 1" tweeter with a cup that didn't seperate. The tweeter speaker itself was 1" but the body was much bigger.
Old Apr 27, 2005
I was saying that they should fit. True, some of the cups would need more modification than others, and more than likely the plastic in the bottom of the existing cup will have to be removed. I did my first set with a razor blade, exacto knife, 40 grit sand paper, and finished with 120 grit. It too a little longer than the dremel, but it's not too hard to manage without.
Old Apr 27, 2005
BassKadett's Avatar
Thank you all. I think I'll try it out.
Old Apr 27, 2005
J187's Avatar
Yeah, I generally stick to razors and exacto knives when working with small areas of ABS plastic - much cleaner and easier than a dremel. A bic lighter to heat up the blades makes slicing through much easier too. Hey my outlook is any tweeter will fit there, it's just a matter of how much modding your willing to do.
I had a kid ask me once, "hey will an 8" subwoofer fit in my door?" I said "yup - we'll have to completely rebuild your trim panel from fiberglass, but It'll go in."
Old Apr 27, 2005
BassKadett's Avatar
haha Very true. I just ordered my Kicker components. I can't wait to install them! Yeeeeeah!
Old Apr 27, 2005
Rufus's Avatar
I posted a thread on how I did mine including how I mounted them behind the sail panels.
Old Apr 28, 2005
drummerboy990's Avatar
drummerboy990 is an unknown quantity at this point
I'm just curious, are you looking to flush mount them in the sail panels or are you going to have them angled?
Old Apr 28, 2005
BassKadett's Avatar
I'm really not sure yet. I'd like to angle them towards me as much as possible, but I'm not sure that's possible with the EX sails. If I knew how to glass I could make it exactly how I want with the ones I have now. Any ideas?
Old May 10, 2005
BassKadett's Avatar
Well I got my components last Thursday and picked up the EX tweeter pods and installed the tweeters today. It took me about an hour of being moderately careful and I think they came out great. This is my first time doing something like this, but it was pretty easy. Just grinding/sanding/cutting the inside so they fit perfectly. Here's one of em.
Damn I love my new camera!
Old May 11, 2005
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
looks nice! very clean. I'm planning on doing this with a pair of MB Quarts hopefully early this summer.
Old May 11, 2005
J187's Avatar
Quart tweeters fit perfectly, minimal effort
Old May 11, 2005
BassKadett's Avatar
Thanks! I had to use a bit of finesse to fit em in there. There was a little bump on the inside of the pod that I knew had to come off and I took maybe 1mm off of the entire inside diameter. I also had to grind away some in the corner and side of the pod to get the clearence I need to get a perfectly flush fit.
BootyDo
Jun 21, 2016 03:45 PM
carid
Aug 4, 2015 08:56 AM
jferristx
Jul 8, 2015 10:09 PM
