HELP! 2002 OEM style FOG LIGHT install
hey i was installing the oem style fog lights and thought i finished and did everything right but they didnt work!. Does anybody have a Detailed DIY or can anyone guide me through the install.... i plugged in the harness that goes to the fuse box and i also plugged in the wire that goes into the engine compartment hookin up to the fog lights and it still doesnt work can anyone help please.. thanks
Quick question .. as I know its usually the case with the installing of them - are your driving lights on (as well as the switch for them) ? Without the driving lights on, due to the default wiring, they wouldn't work.
Or maybe the switch you got is broken
My $0.02 on the matter, as I've been researching this diy/install in preparation for my own
Did you make sure the fog light harness was probperly grounded? I believe if its anything like mine there is a ground terminal on the fog light harness that needs to be hooked up.
Also, I agree with the previous post. Make sure your lights are on and at low beam I think.
well do you mean the fuse box under the steering wheel.. right now i have (1)4 pin and (1) 1 pin connected to the fuse box... the other harness i have is one with like (3) 1 pin connectors and on the end (1) 4 pin connector and (1) 1 pin connecter (blue/red wire) I connected that 1 pin (blue/red wire) to the harness connected to the fuse box.. but theres still one 4 pin connector that i dont know where to connect... Is it in the middle where there is a 4 pin connection open on the fuse box (above and to the right of where the other connectors are plugged into?) ahh lol
One Slow Civic.... But I can take turns pretty well :-)
The 4 pin, its a female right? If it is, thats just for extra accessorys. Don't worry about that. How about the relay, did you remember to connect that?
I had my oem style fogs installed a couple weeks ago. Mine didnt work initially cuz there was a short in my switch and every time the light is turned on the fuse blows. I got a new switch from the seller and it works now. So check your fuse and the switch.
well i finally got them working.. they look really sweet with the Yellow yellow bulbs in there... what i did was wire them straight into my parking lights.. which is pretty cool because now i dont have a switch for them and they go on with the parking light... and i also dont have any wires running through the firewall... i only used the fog light harness and ditched the other 2.
CarStuff
Dec 6, 2020 12:52 PM
