HELP! 2002 OEM style FOG LIGHT install
Old Apr 24, 2005
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
hey i was installing the oem style fog lights and thought i finished and did everything right but they didnt work!. Does anybody have a Detailed DIY or can anyone guide me through the install.... i plugged in the harness that goes to the fuse box and i also plugged in the wire that goes into the engine compartment hookin up to the fog lights and it still doesnt work can anyone help please.. thanks
Old Apr 24, 2005
Karumba's Avatar
Boredom causes changes ;)
Quick question .. as I know its usually the case with the installing of them - are your driving lights on (as well as the switch for them) ? Without the driving lights on, due to the default wiring, they wouldn't work.
Or maybe the switch you got is broken
My $0.02 on the matter, as I've been researching this diy/install in preparation for my own
Old Apr 24, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Did you make sure the fog light harness was probperly grounded? I believe if its anything like mine there is a ground terminal on the fog light harness that needs to be hooked up.
Also, I agree with the previous post. Make sure your lights are on and at low beam I think.
Old Apr 24, 2005
Eman's Avatar
Eman is an unknown quantity at this point
Tray Handa-Accessories.com, they have the install instructions for the fogs.
Old Apr 24, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
also make sure you have a fuse in the fuse box for the fogs...if the car didn't come with them from the factory, there won't be a fuse there.
Old Apr 25, 2005
thanks for the replies do you know where the fuse for the fog lights are located?
Old Apr 25, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
Did you plug both harness's into the fuse box? There's two.
Old Apr 25, 2005
well do you mean the fuse box under the steering wheel.. right now i have (1)4 pin and (1) 1 pin connected to the fuse box... the other harness i have is one with like (3) 1 pin connectors and on the end (1) 4 pin connector and (1) 1 pin connecter (blue/red wire) I connected that 1 pin (blue/red wire) to the harness connected to the fuse box.. but theres still one 4 pin connector that i dont know where to connect... Is it in the middle where there is a 4 pin connection open on the fuse box (above and to the right of where the other connectors are plugged into?) ahh lol
Old Apr 25, 2005
tbaleno's Avatar
could it be for your switch?
Old Apr 25, 2005
Blahman2's Avatar
The 4 pin, its a female right? If it is, thats just for extra accessorys. Don't worry about that. How about the relay, did you remember to connect that?
Old Apr 25, 2005
dalaw's Avatar
Bone Stock!
I had my oem style fogs installed a couple weeks ago. Mine didnt work initially cuz there was a short in my switch and every time the light is turned on the fuse blows. I got a new switch from the seller and it works now. So check your fuse and the switch.
Old Apr 25, 2005
Blahman2's Avatar
No, couldn't be.
Old Apr 25, 2005
Blahman2's Avatar
Well there is a fuse on the wire. You can check that.
Old Apr 25, 2005
mikenam's Avatar
mikenam is an unknown quantity at this point
http://www.partscheap.com/PDF/Civic03/2003%20Civic%202-%20and%204-Door%20(EX,%20LX)%20Fog%20Lights.pdf
hopefully this guide will help you
Old Apr 29, 2005
well i finally got them working.. they look really sweet with the Yellow yellow bulbs in there... what i did was wire them straight into my parking lights.. which is pretty cool because now i dont have a switch for them and they go on with the parking light... and i also dont have any wires running through the firewall... i only used the fog light harness and ditched the other 2.
Old Oct 14, 2007
breault5's Avatar
breault5 is an unknown quantity at this point
Re: HELP! 2002 OEM style FOG LIGHT install
hey how do u do that???
put them throught the parking lights??
Old Oct 15, 2007
electric130's Avatar
he connected the power to the parking light power so they come on with the parking lights. he didn't physically put them in the parking lights.
Exterior
Nov 28, 2025 05:23 PM
CarStuff
Dec 6, 2020 12:52 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
disaster
Nov 7, 2001 05:30 PM
