Trouble Shifting In Reverse (manual)
Old Jan 7, 2002
CaptainAmerica's Avatar
CaptainAmerica is an unknown quantity at this point
I have a 5 speed EX. Not all the time but often enough I have a lot of trouble shifting into reverse. All of the other gears shift very smoothly so I don't think the clutch needs adjustment. To fix the problem I usually need to shift into 1st or 4th while parked before shifting into reverse.
Anyone else with this problem? I'm only at 1400 miles so I figured I'd wait until the 1st service at 5k unless the problem gets real bad.
Old Jan 7, 2002
icey's Avatar
icey is an unknown quantity at this point
yeah its like that on all the civics i think..cause my dad has an old civic hatch and it has the same thing....i just go into second and then reverse...no biggie
Old Jan 7, 2002
DHOWPB's Avatar
DHOWPB is an unknown quantity at this point
The transmission has a lockout to prevent the driver from shifting into reverse from 3rd, 4th, and 5th gears, so you don't accidently go into reverse while driving.
[IMG]i/expressions/beer_yum.gif[/IMG] [IMG]i/expressions/beer_yum.gif[/IMG] [IMG]i/expressions/beer_yum.gif[/IMG]
Old Jan 7, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
doesn't the manual tell you to wait 3 secs b4 you shift into reverse from neutral?
Old Jan 7, 2002
Typically I park it in neutral so the car is started in neutral and there is probably more than 1/2 a minute between the start time warming up and when I go to back up. It sounds like this isn't such an unusual issue so I won't sweat it. My wife's Subaru has a similar behavior where I often need to shift it to first before I can go into reverse.
Old Jan 8, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
pretty much every 5spd I've ever driven has this problem. Solution (got this from the manual in my old toyota)...
If you're having trouble engaging reverse, put the car back in Neutral, Press the Clutch to the floor, Release it. Then try Reverse again. Works almost every time (for me at least)
Old Jan 8, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
i wonder if that was why my 88 dodge omni sometimes had problems going into reverse
Old Jan 8, 2002
insan's Avatar
insan is an unknown quantity at this point
same here, but just make sure the car is siting still before u put in rev..
Old Jan 8, 2002
kori's Avatar
kori is an unknown quantity at this point
mine does that too, i have a 5-speed LX almost at 10,000 miles and it sticks sometimes when i go to put it in reverse. almost always when i go to back out of my driveway, i have to wiggle it around to a couple gears before putting it in reverse..i think it must be a safety thing, like someone else said, cause like yours, mine goes into all the other gears smoothly, except rev.
Old Jan 8, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
<< If you're having trouble engaging reverse, put the car back in Neutral, Press the Clutch to the floor, Release it. Then try Reverse again. Works almost every time (for me at least) >>
Double clutching, I do this in between every gear, while driving, make the shifts MUCH smoother, you kinda have to relearn how to drive but im just as fast now with this as I was the old way, plus my girlfriend doesn't complain about the neck jerks anymore, though i think this was due to the pos tranny in my s-10
Okay well i don't put it in to reverse every time, but i pull it out of gear, clutch in, clutch out, then in then next gear, then release and gas.
Old Jan 8, 2002
I've never actually known what double clutching was. thanks. I've been told that it's using the dissengaging and engaging the clutch midway through a gear to keep rpms up. but I knew that one wasn't true.
Thanks
Old Feb 3, 2002
Todd1's Avatar
Todd1 is an unknown quantity at this point
ease your foot off the brake!!!! that should help!!!!!
Old Feb 3, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
All manual are like these if having problem shifting to reverse Put it to 1st gear then put it in reverse
Old Feb 3, 2002
I've been using NitehawkVTEC suggestion of putting it neutral, releasing the clutch, depressing the clutch and trying reverse again. Just as he wrote it works almost every time.
Old Feb 3, 2002
mykel115's Avatar
Yeah I think that would work. But when shifting to 1st then reverse you don't need to release the clutch. Anyway do what suit you best
wasa67
Jun 27, 2015 01:47 AM
Srudet
Jun 7, 2015 09:34 AM
Blazz
Jun 4, 2015 01:04 AM
cruisers10
May 12, 2015 10:46 PM
Russps
Nov 8, 2001 02:00 AM
