Manifold Question
Old Mar 29, 2005
15seccivic's Avatar
15seccivic is an unknown quantity at this point
Manifold Question
i have the turbo system & everything from it off my 1st gen gsx, what or who makes a manifold to bolt this turbo system to our motors... not sure if i wanna even do it but it could be fun.
Old Mar 29, 2005
PunkingCivic's Avatar
I need TP for my bunghole
www.dezod.com makes a manifold
HKS makes a manifold
obx makes a manifold
stafford fabrication makes a manifold
www.revhard.com makes a manifold
Old Mar 29, 2005
cambo's Avatar
I wish I was asian
Greedy makes a manifold
obx sucks
stafford fabrication went out of business i believe.
tsi has a manifold
Old Mar 29, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
tsi sucks
You'll need a custom manifold made for the DSM t25.
Call dezod and see what he can do.
Old Mar 29, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
max rev makes one too. and it has gotten good ratings. but its for the t3/t04E. it looks the same as the one by dezod, but the max rev makes that dezod up top look like poopy. the max rev is all shinny and polished - not chrome.
Old Mar 29, 2005
Modern chrome won't last on a turbo header.
Old Mar 29, 2005
mallison's Avatar
mallison is an unknown quantity at this point
yes the maxrev one will fit BUT if you use anything liek the tail wastegate the 38mm i think will rub on the hood of your car and you cant even put the nipples for the air fitting on cause then you cant even shut the hood and IT IS NOT CHROME all of maxrev's stuff at the base price's are not finished, nothing comes polished or chromed and on top of that when you bolt maxrevs mani on the dump tube ends up sticking in the fan and the turbo housing rests on the fan housing which on top of all that maxrev doesnt make that mani, reason i know this is cause i ordered a kit and nothing fit at all nothing was finished you could'nt bolt the downpipe on cause the bend of it would'nt allow u to put the bolt in, and the previous stuff and the manifold is from tiawan, it plainly states that on it when you get it, you have to hack up the bumper for the intercooler a brake line is in the way for the charge piping and nothing is to fit. they have been sending the wrong hardware out and it took them more than a month to get me my kit and when i got it and found out nothing work i sent it back and got a tsi which is ALOT better went on so easy comes with alot of stuff and when i sent it back to get a refund over a month ago i still have'nt got them to credit my card, they never will answer the phones and they are hard as hell to get ahold of, i would most likely not do business with them agian
Old Mar 29, 2005
bradmanuwf's Avatar
oh, and I was just talking about the manifold, not the whole kit.
Damn, mine works fine. I had no probs with it at all. it bolted right on. I had to trim that black stuff out of the bumper, but that is no biggie. I think it looks better like that. and I have some dual flex-a-lite fans so I have lots of space between the turbo and fans & dump tube and fans. sorry yours didn't work out well cause mine is great and all shinny
Old Mar 29, 2005
Old Mar 29, 2005
C2i0v0i1C's Avatar
SuperMODrizd
the manifold created to wastegate issues for me
Old Mar 29, 2005
Havok2k1's Avatar
Wicked Pissah Admin
....added to turbo faq.....
Old Mar 29, 2005
mallison's Avatar
Oh i also forgot about one thing, that kit is and was designed for a carb emissions vehicle and not federal so the downpipe wont work right unless they have fixed that and it doesnt come with fuel stuff they did send me a fitting for a steel oil pan and not aluminium, umm comes with a big turbo that may or may not be the best for our cars or setup that whoever is going for w/o a built engine, oh ya the kit does not come with a dump tube in the base kit its extra and that is just the tube which will end up in your fans and it dumps to atmosphere and it was designed off a civic with a close coupled cat which also has all the a/c lines tucked away which a federal does not, all in all i would'nt recomend the kit for a street car or definatly not a bolt on at all and i would only use that kit for a big project and built engine, otherwise i would get the tsi kit which basically bolted right on.
Apparrently since going thru this with me they have been working on the kit and modifieing the kit to work better on a federal, but it will def not be a bolt on kit, its about a week long project at a shop.
Oh here is a pic of the kit out of the box with the optional dump tube.
ID:	50866   Click image for larger version
ID:	50867   Click image for larger version
ID:	50868   Click image for larger version
ID:	50869   Click image for larger version
Old Mar 30, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Im sorry you had all the problems with this kit. I recieved one of the FIRST kits that maxrev ever made. The only problem that this kit has is that the external wg does hit the hood, and the dump tube does waste into the atmostphere. I plan to get the external wg turned side ways at a 90 degree angel and route the extwg dp to the turbo downpipe. It states on their website that this kit is NOT street leagal. This kit also came with the MF2 injector controller, witch i have had NO problem with at all once i figured out how to work it. 183whp/175 lbs tq on 7psi, go figure
Old Mar 30, 2005
HellSpawn's Avatar
HellSpawn is an unknown quantity at this point
Whats wrong with the OBX manifold? I was thinking about getting it from Ebay today.
Its only 175 bucks!
Old Mar 30, 2005
bradmanuwf's Avatar
the obx turbo manifolds crack a lot. they're good for an N/A motor, but not turbo. I had an N/A OBX header and it worked great. not probs. and yes, by looking at those pics, they have changed the kit a little bit. my wastegate doesn't hit the hood, and the charge pipes are diff. too. I like the way the dump tube sounds when the wastegate opens...sounds like a jet kinda...its pimp. It only took me to about 4hrs to install it by myself. was pretty easy. the hardest part was shoving the bumper back on....lol
Old Mar 30, 2005
HellSpawn's Avatar
Good info.
Im trying to build a cheap turbo (under 1500 bucks) so I have been checking out stuff on ebay. Theirs a SUPER XS Power T3 Turbo Brand New .42 .48 for $199 bucks! I know you get what you pay for but man If I could get a turbo and manifold for under 500bucks Im half way home.
The downside for me is I dont know jack crap about real world turbo stuff. I have read all the post on this site (excellent stuff) but its scary trying to buy this stuff and make sure it will work.
I like the look of the HKS manifold (very clean) but I think it will only work with T25's.
Old Mar 30, 2005
bradmanuwf's Avatar
yeah, my turbo wouldn't work on the HKS. it would hit the fans or the that support bar down the middle. but it does look clean.
Old Mar 30, 2005
HellSpawn's Avatar
Doesnt seem like a lot of good options available. I really hate to spend 400+ but I guess thats the best choice.
I did some searches for the OBX manifold and man their are some major problems with that crap.
Oh well so much for cheap solutions.
Old Mar 30, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
^^good luck trying to put together a decent turbo kit for under $1500 and getting a turbo and manifold does not make you "half way home"
Old Mar 30, 2005
bradmanuwf's Avatar
yeah, good luck with that. and yeah, there aren't many options for the 7thgen yet. but there are more and more things coming out for it. just going to take some time.
Old Mar 30, 2005
HellSpawn's Avatar
I hope more stuff comes out. Im so tired of seeing all this stuff for the older civic's and only 1 or 2 decent kits for ours.
Its been about a year since I was last checking out this board and at that time SF turbo's seemed to be the bomb! I come back and things have changed alot.
I guess their is always the electric turbo!! Just kidding ( - :
Old Mar 30, 2005
allmotor's Avatar
nor cal 7thgens
lol get the obx turbo mani and see how long it last
Old Mar 30, 2005
HellSpawn's Avatar
I was just wondering how long it lasted for some of the guys that had it before. Its so hard to believe someone would make something that bad.
So in terms of best product (for the price) and best under hood fit who do you guys say go with?
Im taking OBX of the list for obvious reasons and the HKS for bad turbo placement.
Old Mar 31, 2005
bradmanuwf's Avatar
just go with the dezod. dezod seems to be good guy with some good info and products.
herbiej
22
Aug 23, 2015 01:02 PM
bhollie
Aug 12, 2015 09:58 PM
Theshwartz35
Jul 17, 2015 11:13 PM
Ccoop87
Jul 9, 2015 03:26 PM
hayden55
Jul 8, 2015 11:38 PM
