Sunroof Light
Old Mar 1, 2005
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
Sunroof Light
Does the Sunroof button next to the Cruise Control and Mirror light up? I just got the car and that button doesn't light up at night and I need to know if it is like that or if to get it fixed?
Old Mar 1, 2005
909's Avatar
909
909 will become famous soon enough
no .
Old Mar 1, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Yes. Actually it does. I'm assuming that since 909 says it doesn't that his light behind it is dead. Mine has a loose connection/failing bulb because it's on sometimes, off sometimes, but the 3-piece button does illuminate.
Old Mar 1, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
That makes me want to go check mine because I don't think mine does either? But if it does light up, then it's been out for a long time because I don't ever remember it lighting up?
Old Mar 1, 2005
Kizuel's Avatar
Kizuel is an unknown quantity at this point
Yes, the 3 settings are illuminated.
Old Mar 1, 2005
909's Avatar
909
Mine never lit up either, but I guess it will after tommorrow.
Damm something else to take apart .. Great :P
Old Mar 2, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
its not hard to take it apart. Its the one screw. Then pull. Its got to clips on the bottom. Then disconnect the wire hardness's and its free. Pop your buttons out, and you will notice little plastic things in the holes on the sides. Use a small flat head screw driver to make sure they are tightend, or even replace the bulbs.
Hope I helped you out man.
Old Mar 2, 2005
typeRDreamer's Avatar
typeRDreamer is an unknown quantity at this point
YUp it lights up!
Old Mar 2, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Mine lights up too....see, this is why our cars are only 15 grand...half of them suck *****
Old Mar 2, 2005
Bires's Avatar
My integra had the exact same problem.
I love my little economy car. What counts is in great shape, even if a few trim panels and buttons remind me it's an economy car.
(Sound dampened properly, our cars feel more solid than Accords.)
Old Mar 2, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
Dammit, I don't think mine lights up either.
Old Mar 2, 2005
It's supposed to. There's a light that twists out. Just open the coin tray, unscrew that screw inside on top, pull out that whole thing, unplug, pop out switch, and pry it open.
Old Mar 2, 2005
CaffeineCulture's Avatar
CaffeineCulture is an unknown quantity at this point
yes, this is redundant, but yah....it DEF lights up....proly some kinda of loose connector or maybe the tiny blub is out....but yah, should be too ahrd to fix.....just take out that middle screw, pop out the plate, unscrew the little place holder, and replace bulb (few bucks from honda).....
Wild Cranker
427
Jan 28, 2016 06:49 PM
Optimus34
May 25, 2015 11:52 PM
ashlava71
May 16, 2015 12:54 PM
TonoAlpha
Apr 30, 2015 04:21 AM
Jandree22
Dec 13, 2001 03:23 PM
