Sunroof Light
Sunroof Light
Does the Sunroof button next to the Cruise Control and Mirror light up? I just got the car and that button doesn't light up at night and I need to know if it is like that or if to get it fixed?
That makes me want to go check mine because I don't think mine does either? But if it does light up, then it's been out for a long time because I don't ever remember it lighting up?
One Slow Civic.... But I can take turns pretty well :-)
its not hard to take it apart. Its the one screw. Then pull. Its got to clips on the bottom. Then disconnect the wire hardness's and its free. Pop your buttons out, and you will notice little plastic things in the holes on the sides. Use a small flat head screw driver to make sure they are tightend, or even replace the bulbs.
Hope I helped you out man.
Originally Posted by Mystic3030
Mine lights up too....see, this is why our cars are only 15 grand...half of them suck *****
I love my little economy car. What counts is in great shape, even if a few trim panels and buttons remind me it's an economy car.
(Sound dampened properly, our cars feel more solid than Accords.)
It's supposed to. There's a light that twists out. Just open the coin tray, unscrew that screw inside on top, pull out that whole thing, unplug, pop out switch, and pry it open.
yes, this is redundant, but yah....it DEF lights up....proly some kinda of loose connector or maybe the tiny blub is out....but yah, should be too ahrd to fix.....just take out that middle screw, pop out the plate, unscrew the little place holder, and replace bulb (few bucks from honda).....
Wild Cranker
427
Jan 28, 2016 06:49 PM
ashlava71
May 16, 2015 12:54 PM
