SRS light won't turn off. Did I break a wire?
Old Feb 19, 2005
Bires's Avatar
Bires is an unknown quantity at this point
(02 coupe)
I removed my seats on Saturday to do some sound deadening work. I've been driving with my front seats installed, but not plugged in for the last 5 days. (SRS light on while I'm driving)
Today, I finished up, secured the seats, and plugged in the two little harnesses under each seat....
the SRS light now stays on.
I've done this thing once before and the SRS light turned off when I plugged in the wires. This time...nope.
So,
Did I break a wire?
Is there a way to force it to think an adult is in the passenger seat?
Old Feb 19, 2005
Bires's Avatar
UPDATE: FIXED!
I searched around the net for the solution (no SRS search results here) and I found it here:
http://www.honda-tech.com/zerothread?id=264288
For posterity, for those that remove their seats and turn on their ignition: this is one of the ways that the SRS computer detects a problem with the sensors.
Since I unplugged my passenger's seat sensors and drove with them disconned, the computer turns on the error light and leaves it on so a Honda tech can charge $90 to reset it and look competant.
Anyway...here's a post copy of the procedure:
Originally Posted by dogpile5 fromhondatech
Directions for erasing memory on SRS light
1st you need to either buy or make the "SCS Service Connector." I used a speaker harness for and older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly.
2nd you need to find the MES (Memory Erase Signal) connector which is pictured below: (Click to enlarge)
MES Plug in Fuse box.
**pictures removed at source**
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
I used the paperclip and it worked on the first try.
Old Feb 20, 2005
ImPulse's Avatar
i tried the paperclip thing.. didnt work, so the light has been on for like 2 months =\
Old Feb 20, 2005
Bires's Avatar
I'm faily fond of airbags, so I was really stressed out until I found out what it was.
Old Feb 20, 2005
chrisleecool's Avatar
My SRS light has been on since it was bought..lol
I once took it to the dealer to fix it, but then it turned back on when i was working on my car with some soundsystems.
I'm just too lazy to do this......
Old Feb 21, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
when me and 909 were installing my new RSX seats we made the same mistake of starting the car w/o the seats + srs attached. Took it ot honda they got it off
Old Feb 21, 2005
2K1Civic17"Gabe's Avatar
Retry it, it ill work. Just do it a few times, exactly how stated on the DIY from this site. I did it and it worked. Is sort of a pain to get right though.
Old Feb 21, 2005
flotsamm's Avatar
Where is the MES connector located in our cars? Thanks!
Old Feb 22, 2005
Bires's Avatar
On the fuse box, behind, below, and the right of the stearing column. It's a yellow plug that is "plugged into" the fuse assembly, but is only there so it has a place to be-it isn't plugged into anything active. The wires are green and something...
Old Mar 22, 2005
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Originally Posted by Bires
UPDATE: FIXED!
so during the procedure you don't have to plug the connector back to the fuse pannel when you start your car?
Old Apr 3, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
I dont get how to do this either. What are you supposed to do after you take the plug out? what do you do with the clip ?
Old Apr 3, 2005
im stock now! T.T
heres some pix of the little plug. Its the far most left yellow plug with two wires one of them being green. Push top of the plug and pull, not that hard.
I managed to do this successfully, but after the two blinks, the srs light stays on.... I dont know what to do now because this didnt work for me.
ID:	51191   Click image for larger version
ID:	51192   Click image for larger version
ID:	51193   Click image for larger version
ID:	51194   Click image for larger version
Old Apr 4, 2005
chicohonda02's Avatar
Since 2002 Baby!
sounds confusing
Old Apr 11, 2005
SoufSidah09's Avatar
SoufSidah09 is an unknown quantity at this point
Thanks for the guy that posted this, it worked pefectly for me and it's a lot eaiser than it sounds, did it in like 5 mins with a staple! Saved me blowing money at the dealer, Thanks again!
Old Apr 11, 2005
teampointless's Avatar
Ultimate Member
Next time, might want to check the "Reset your SRS light DIY"
voblak2
20
May 4, 2023 02:08 PM
bo_red
Transmission
May 3, 2015 09:14 PM
shaejb15
Apr 26, 2015 07:44 PM
SimDogg
Nov 27, 2001 04:20 PM
NukeSilo
Nov 4, 2001 09:37 PM
