Sponsored by:
Sponsored by: CARiD
urgent need help fast about muffler
Old Feb 14, 2005
civic_luvr's Avatar
civic_luvr is an unknown quantity at this point
Exclamation urgent need help fast about muffler
i am having a hard time getting the factory axleback off please help me some1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
Old Feb 14, 2005
PunkingCivic's Avatar
I need TP for my bunghole
more info needed.
what is the problem?
Old Feb 14, 2005
civic_luvr's Avatar
muffler bolt a stuck
cant get them loose may i am weak or doing something wrong?
Old Feb 14, 2005
the bolts?
Righty tighty
Lefty loosey
spray some wd40 on it
Old Feb 14, 2005
civic_luvr's Avatar
thanx u
but will have to try 2morrow its time for me to go to work
Old Feb 14, 2005
Man you are being criptic with your problem.
Tomorrow if you have problems in detail
explain your problem
what did you do and then what happened or didn't happen.
Old Feb 14, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
leverage, or heat, or both - these almost never fail
Old Feb 14, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
torque wrench's... set higher then our engine output works perfect.
Old Feb 14, 2005
hotrodcivic2004's Avatar
my civic has no boost
those rear bolts were the easiest to get off IMO. the ones up by the cat r freakin hard i had to use a torch to heat them up. use a long ratchet and soe sort of pipe or somethin for better torque and leverage and they'll loosen right up man.
Old Feb 14, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
wd-40 was my best friend. spray large amounts and itwill come off. any nuts and bolts to remove use wd-40 under there. As for a torch, I dont know if using it will be ideal. Never tried. WD-40 definately works though. You will get steam after first installation but dont worry about it, its normal.
Old Feb 14, 2005
R1Style's Avatar
Liquid wrench.... it's better then WD-40.
Old Feb 14, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
wd-40 is more common in a household though. doubt anyone would go out and buy another product if they have wd-40 at home already.
make sure you dont breathe it when u spray the wd-40 or whichever lube ur using. you can jack the car up for more clearence if you have too, just make sure you do safety first. and no dont use the OEM jack, not trustworthy
Old Feb 14, 2005
Al Gore FTW's Avatar
jdmtytedoridori
i have liquid wrench, but no wd-40
jdawgzcivic
17
Feb 1, 2020 04:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
Dave Brabant
20
Oct 6, 2015 12:44 AM
IronFist
Sep 25, 2015 07:13 PM
yyyktk1
Sep 12, 2015 04:02 PM
