urgent need help fast about muffler
I need TP for my bunghole
Man you are being criptic with your problem.
Tomorrow if you have problems in detail
explain your problem
what did you do and then what happened or didn't happen.
those rear bolts were the easiest to get off IMO. the ones up by the cat r freakin hard i had to use a torch to heat them up. use a long ratchet and soe sort of pipe or somethin for better torque and leverage and they'll loosen right up man.
wd-40 was my best friend. spray large amounts and itwill come off. any nuts and bolts to remove use wd-40 under there. As for a torch, I dont know if using it will be ideal. Never tried. WD-40 definately works though. You will get steam after first installation but dont worry about it, its normal.
wd-40 is more common in a household though. doubt anyone would go out and buy another product if they have wd-40 at home already.
make sure you dont breathe it when u spray the wd-40 or whichever lube ur using. you can jack the car up for more clearence if you have too, just make sure you do safety first. and no dont use the OEM jack, not trustworthy
jdawgzcivic
17
Feb 1, 2020 04:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
Dave Brabant
20
Oct 6, 2015 12:44 AM
IronFist
Sep 25, 2015 07:13 PM
