check engine light
check engine light
i own a 2004 ex coupe with cold air intake a just resently ''hollowed out the cat'' with 3in pipe from cat to custom resonator and muffler ever since i holled out the cat my check engine light came on i took it to honda and they said im throwing the catalytic converter inefficiency code what can i do about this
or buy an o2 simulator if you want to keep it the way it is. what an o2 simulator does is "tricks" your ecu to read the airflow going thruout your exhaust is fine and correct when its really not. only solution i can think of unless you want to put a cat on.
theirs the $20 ones or the exspensive $50+ ones, your call...
Xuhme
21
Aug 7, 2023 03:40 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
