N2o ?
N2o ?
Do you guys think its ok to run the nitrous line through the interior of the car instead of under? I havn't made up my mind which way to run it yet. Through the interior panels would be nice and easy.< just the way I like it.
thats what I was thinking about when I was gonna get some nitrous. I woulda ran it inside my car if its ok. I figured thelines wouldnt get damaged as easily, just make sure the lines arent crimped (is that the word I want to use?). It may be less safe in an accident, just get out of the car, so if its leaking, you dont go crazy than die. God forbid. Good luck
yeah, thats why Im saying get out of the car so he doesnt go crazy and die. I would think breathing that in for a while would make ya really sick or dead.
I was also thinking about the odds of a steel braided hose springing a leak. ..pretty slim. Do you think the tech people at the drag strip would care one way or the other? Thanks for the help.
Well, correct me if I'm wrong, btu they wont let you run if you have it in the cabin will they? I mean that is if they check it
AKA Mr. 60ft. Not to be confused with Civic_Redline
Originally Posted by tfnaaf
mine is inside the car, no problems here
any slips with or without your N20???
How long have you been running N20??
yeah I ran mines inside too, through passanger side not the middle. And yesss you can smell it. You can smeel it even when using it. I actually like the smell, but doesnt mean I literally sniff it jus tbecause i liked the smell. Nitrous makes you high. When I had disconnected my bottle and brought it home, my friends came over and wanted to try it. All they did was knock out for about 5 mins and wake up. Its basically laughing gas that dentists use to make you go to sleep. However, inhaling too much can kill you. I never actually tried inhaling nitrous.
Btw, Im running lines inside and its fine no problems at all. I would think its better running inside, b ut outside should be ok since its stainless steel. I tried hack sawing it and no luck cutting it because its too thick. And getting a blow down tube should be ideal. I want one so I would feel safer, anyone know where to get it? I already have a hole premade so it can be routed outside the car.
SpdRcrChk
21
Mar 12, 2002 11:22 AM
