Need help with removing a dash and dash pad
Old Feb 4, 2005
buck's Avatar
buck is an unknown quantity at this point
I have a 2002 civic coupe, i had to get a new instrument panel pad and i started to take things off and i cant seem to get the dash too come out if anyone could help me that would be great! If anyone knows any good site where i can see some pictures that would be wonderful.
Thanks.
Old Feb 4, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Look at the dash removal DIY.
http://www.7thgencivic.com/forums/sh...d.php?t=156990
Of course, pics aren't working...
Old Feb 4, 2005
hotrodcivic2004's Avatar
my civic has no boost
ok noob...rule #1....SEARCH...theres a search button in the upper right hand corner of the IE box. 2nd.....yeah that DIY is great i used it. theres a screw u gotta undo and then pry it out....u'll see the rest is self explanitory.
Old Jun 27, 2005
gnat1000's Avatar
gnat1000 is an unknown quantity at this point
does anyone have a DIY for this with pics?
Old Jun 27, 2005
2K1Civic17"Gabe's Avatar
If you are just trying to replace the gauges, you dont need to take the whole dash out. Jsut 2 screws above the black bezel around the gauges. Than there are 3 more than you see easily. Than just pop the 2 large clips out, and it comes right out.
It sounds like that is what you want, not the whole dash. If it is the dash, look all under the dash, get all screws, take the glovebox off by taking the screws off the bottom of it while its closes. Take out the radio centerpiece, and look for the screws hidden all around in there, usually you can not see them, but you can see the plastic where they screw into. Than once you take out your gauges and bezel by the above paragraph, you want to take the steering wheel off. You just take the 3 screws out from underneath the wheel and pop the 2 pieces off. Than you get a T screwdriver (star shaped), and get the 2 screws holding the wheel in. Than you should be able to take the cover off the steering wheel, and unhook the airbags. Before you unhook any airbags, MAKE SURE THE CAR HAS BEEN OFF FOR AT LEAST 15-20 MIN JUST TO BE EXTRA EXTRA SAFE. I think 8 or 10 min is what Honda recommends. To get the other airbag on the passenger side, go where you took out the glovebox and look up. You will see the airbags being held on by 2 or 3 bolts. Take them bitches off, and unhook them. Than push it up a little bit til it starts coming out of the top of the dash. Go up and pull it. Now if you got all the screws, the dash is loose, and able to come out. If not, look for where its sticking. guaranteed youll miss some.
I did all this before I found the DIY. About 2 days before as a matter of fact. I was a little angry when I found it. But just do what i said, and take every screw out attached to the dash. When out, its a good time to clean the ventilation pipes. The plastic things the a/c flows through. i sprayed a bunch of water down there, and cleaned my dash behind it. Also cleaned all the dust (which youll see) all over the wiring and whats left in the car. You can do this with one person, its easy once all the screws are out. I took it out and installed it by myself.
Hope this helps
Peace
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
DAC
Jun 18, 2015 10:00 PM
edgenet
Apr 28, 2015 07:49 PM
honda4life
Jan 8, 2002 12:06 PM
