is there any body using a K20A??
Old Jan 27, 2005
Bmkarr's Avatar
Bmkarr is an unknown quantity at this point
i was wanting to do a k20a and was trying to figure out what else i will be needing if i ordered this engine http://www.naganojapanese.com/k20a.php off that website. thanks
Old Jan 27, 2005
abmerop18's Avatar
Jam out with your clam out.
yes, and read this
http://www.7thgencivic.com/forums/sh...d.php?t=141122
Old Jan 27, 2005
Bmkarr's Avatar
i've read the entire faq thread, i understand i need the mounts and powersteering from the Si and Subframe and such but that website has stuff with the swap like suspension and other stuff like that. i was wondering if since im getting a JDM engine if i need other special stuff that i cant get off a RSX-Type S front clip ( I.E.- KPH to MPH)
Old Jan 27, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if you're keeping 4 lug ... get Si axles. If you going 5 lug with type S suspension, get type S axles ... if you're going 5 lug with type R suspension, get type R axles.
Old Jan 27, 2005
Bmkarr's Avatar
do i just need to take the speed sensor off the type s for the mph conversion
Old Jan 27, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
what? ... you don't need anything like that.
Old Jan 27, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Old Jan 27, 2005
doubledeuce2k2's Avatar
you also need to reflash the RHD module
Old Jan 27, 2005
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
Are you even doing the swap urself? Or are you having a shop do it? Cause if your having a shop do it, and you get the engine from them, the vendor usually sends all the parts u need for the engine with it, so you don't have to worry bout it.
Old Jan 27, 2005
Bmkarr's Avatar
the reason im askin about the speed sensor is cuz when you do a sr20det swap into a 240 you have to pull the speed sensor off the k24. i was wondering if you have to do that as well with the k20a.
i will be having a shop do the swap and i will be ordering the k20a online cuz they are expensive as hell out here
Old Jan 27, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
so if yoru having a shop do it...just let them worry about that
Old Jan 27, 2005
Bmkarr's Avatar
well you know shops if they dont know what to do then they dont do it and they dont say
SammySC
121
Apr 7, 2017 07:43 PM
C-Hamm
Sep 28, 2015 10:31 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
Bricoleur
Sep 9, 2015 12:30 PM
