is there any body using a K20A??
i was wanting to do a k20a and was trying to figure out what else i will be needing if i ordered this engine http://www.naganojapanese.com/k20a.php off that website. thanks
i've read the entire faq thread, i understand i need the mounts and powersteering from the Si and Subframe and such but that website has stuff with the swap like suspension and other stuff like that. i was wondering if since im getting a JDM engine if i need other special stuff that i cant get off a RSX-Type S front clip ( I.E.- KPH to MPH)
Desperate Custom Swapper Speed Freak
Are you even doing the swap urself? Or are you having a shop do it? Cause if your having a shop do it, and you get the engine from them, the vendor usually sends all the parts u need for the engine with it, so you don't have to worry bout it.
the reason im askin about the speed sensor is cuz when you do a sr20det swap into a 240 you have to pull the speed sensor off the k24. i was wondering if you have to do that as well with the k20a.
i will be having a shop do the swap and i will be ordering the k20a online cuz they are expensive as hell out here
Sep 27, 2015 11:33 AM
Bricoleur
Sep 9, 2015 12:30 PM
